Question about Optics
When using Meade DSI camera I get an error 5 images failed xfer, disconnect all other USB 1.1 devices or switch to USB 2
Reads zoom error when turned on
The device requires restoration achieved in two processes
perform a check
1. Power off completely the camera.
2. Remove all power devices or batteries
3. Check the entire device for damages
4. Make observation notes about any malfunct features
5. Replace batteries and removeavble parts properly with caution that every feature is intact.
6.If the device still displays error message consider the second phase explained
a. The device program features are jammed only possible solution is performing a software update or upgrade
1. updates are achieved by contacting the device;s technical support deparment
2. Upgrades can be performed by acquiring an installation kit in which instance requires technical expertise to perform an intergration restoration
Important notes
1. Apart from the message received does the device malfunction?
2. Your camera would be displaying an image similar as flash screen or screen saver that can be fixed quiet easily
a. use the menu buttons to select the option of settings
b. set the picture to be displayed on the appears screen area once powered on.
c. Possibly alter the entire image displayed as desired by yourself.
4. A screen saver could only be deleted,, hidden, or replaced with a preferable image
5. Possibly, the words ZOOM ERROR could changed to WELCOME TO OLYMPUS STYLUS
Refer to the camera manual for diagnostic support
Dec 02, 2010 | Olympus Stylus 730 Digital Camera
Where can I get the windows 7 drivers for meade's DSI and DSI Pro imaging cameras?
Meade has not made windows 7 drivers. The claim to be working on them, but they may be a loooong time coming. Sorry.
In the mean time, use the current driver: It works with x86 (32 bit) windows 7.
Apr 03, 2010 | Meade Deep Sky Imager II Camera
Cannot download images
Use a separate card reader to download the pics.
Sep 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Is there any way to download the set-up disk for my jvc gz-hd7u
Connecting the Camera to the PC
Preparation:
Set the camera’s power/mode switch to OFF.
NOTES
• When the USB cable is connected, turning on or off the camera causes malfunctions of the PC.
• Connect the camera directly to the PC, not through the hub.
• Do not use an extension USB cable.
• Saving the wrong kinds of files in a recording medium or deleting files or folders from a recording medium can cause problems with the operation of the camera. When it is necessary to delete a file from a recording medium, delete it through the camera. Also, do not move or rename folders and files in the medium on PC.
• Never disconnect the USB cable while the access/charge lamp on the camera lights or blinks.
1 Create a folder to back up files into.
2 Set the camera’s power/mode switch to STANDBY/ON.
3 On the camera, move the set lever to
\/ / /\ to select [PLAYBACK ON PC],
then press down.
4 Double-click [EVERIO_HDD] or [EVERIO_SD].
5 Select the folder that you want to back up, and drag & drop it into the folder you created in step 1.
SD_VIDEO:
Folder that contains video files. If you want to back up fi les individually, open this folder, and drag & drop folders such as [PRG001] one by one.
DCIM:
Folder that contains still image fi les. If you want to back up fi les individually, open this folder, and drag & drop files such as [PIC_0001.JPG] one by one.
When you have finished operation
Always follow the procedures below when disconnecting the camera, or turning off the camera/computer power.
Failing to do so may cause damage to the camera and computer.
1) Confirm that the access/charge lamp on the camera does not light or blink. (If the access/charge lamp lights or blinks, wait until it is turned off before proceeding.)
2) Double-click the [Safely Remove Hardware] or [Unplug or Eject Hardware] icon in the status bar.
3) Select [USB Mass Storage Device] or
[USB Disk], and then click [Stop].
4) Click [OK].
5) Disconnect the USB cable.
6) Turn off the camera and PC.
Sep 20, 2009 | JVC Everio GZ-HD7 Camcorder
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Driver (Windows Driver Model) or documented DLL for Meade DSI III
the driver is packaged in the latest version of the envisage software, available on their website
Mar 28, 2008 | Meade Deep Sky Imager II Camera
Transferring pictures
A couple of things you can try:
1. Insert the Camera's USB cord to another USB port of your PC;
2. While disconnected from the PC, verify that the pictures are still inside the camera's memory;
3. Reset the camera (power on/off);
4. Check the camera's batteries;
5. Reboot your PC with the camera attached via the USB;
6. Remove the memory card from the camera and try uploading using a card reader;
7. Uninstall all instances of your USB in your PC's Device Manager, reboot and allow the PC to auto-detect  and auto-install necessary drivers; and
8. Verify that the software/drivers for your camera are installed correctly with no yellow or red markings.
Hope this be of some help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Cameras
Optics Logo
53 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
