Question about NetGear Computers & Internet
When I type the ip address http:192.168.0.1 in and hit enter like it said to do it doesn't ope the admin. window it just opens the all the web pages for that ip.
I have it plug in to a dsl modern i just want to run two computers off of it.
  • jeff bounds Feb 19, 2012
    the router is netgear rp614 v2
    Scholar:
  • 106 Answers
This is an internal network IP address, it doesn't go any further than your own local network (LAN).
Are you sure that is the IP for the router? If you provide the name and model number for the router, I can tell you if your address is right.
Routers usualy have 192.168.1.1 as IP adress. other options are:192.168.1.100192.168.100.1
Posted on Feb 19, 2012
  • 35 Answers
SOURCE: d-link dl-624
Check on computer what ip address router is assigning computer.If not reset router it should set it back to factory defaults.
Posted on Aug 27, 2008
mastersaintx
  • 928 Answers
SOURCE: belkin wrong ip address
You may mean that it is not giving the right address to your computer. Try pressing the reset button for about 20 seconds then unplug the power wait for about 15 seconds then plug the power back in then restart your computer.
If you need further help just message back.
Posted on Nov 26, 2008
  • 30 Answers
SOURCE: ip configuration
Does your friend and yours IP settings the same?To clarify you would have 2 types of connection from your ISP.The 1st type of connection is that the authentication happens in the modem through the PPPOE UN/PW and the IP configurations are done in the modem and as such wont require to configure the IP settings when the windows is reinstalled.However the 2nd type of DSL service is that the IP settings are done in the windows and does not require any PPPOE username and password to authenticate.You would have to verify with your ISP which type of service you have and if you require any change order to make it the same way your friend has.
Please let me know any clarification you would require for this issue.
Posted on Apr 20, 2009
nyilasrobert
  • 627 Answers
SOURCE: comuter gets a 168 private ip
enable DHCP on the router and you'll get the right ip adress
Posted on Aug 05, 2009
Tom Marvolo
  • 708 Answers
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Posted on Jan 10, 2010
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have access point TL-WA500G and I can`t open my admin i do reset`t but stell can`t open my admin .
The Issue you are having is that you might be typing in the wrong IP address for the Access Point.
Follow these Steps Below and this should fix your problem.
Step1:Open your web browser.
Step2:Type in IP address http://192.168.1.254 in the address field of web browser and press Enter.
Step3:Enter admin for the User Name and Password (both in lower case letters).
Step4:Then click OK or press Enter.
Go to This web Address to get a copy of the manual for your device in PDF Form.
http://www.tp-link.com/english/soft/TL-WA500G_User_Guide_201003.pdf
Apr 29, 2011 | TP-LINK TL-WA500G 54Mbps Wireless Access...
I have lost my setup cd and now I can not acces my router anymore It's a wrt54g by linksys. what's the ip adress for my router?
Typically your router's ip has to be 192.168.1.1 or 192.168.1.254 and the credentials admin / admin. In case the router's ip is modified you can do this simple tip in order to locate the new one:
Connect your computer with ethernet cable at the router and after the connection has been established, hit start - run - type cmd. At the new black window type ipconfig and hit enter. You will get the results for ethernet connection (in case of a laptop you will get the wireless connection too). The line for Default Gateway is the router's ip address.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Linksys Wireless-G WRT54G Router
How do I launch the "web browser"?
To open the set up page of the router of the router , one of your computer should be able to go online through the router.
It could be a wired computer or wireless computer.
If it is a wireless computer then make sure that the computer is connected to your own wireless network.
Do not change any wireless settings on the router using a wireless computer.
OK ! Now you have a computer online through the router and you want to open the set up page of the router.
First step is check the IP address of the computer.
Check the IP address and the Default gateway on the computer.
For Windows XP
START ==> RUN ==> type in cmd in the RUN box==> click OK or Hit ENTER . You will see a black window that is a command prompt . In the black window type in " ipconfig " ==> and Hit ENTER on your key board .
For Windows Vista and Windows 7
click on START ==> type in cmd in the start search box ==> enter ==> you will see the black window. Type in " ipconfig "you will see a lot of information. Try to find out the local area connection IPv4 address .
Note down the Default gateway number.
For MAC OS
Click APPLE icon in the right top corner of the computer. Go to System Preferences ==> go to Network ==> you will find the option Built in Ethernet or Airport whichever is connected. If you go to that you will find the Ip address and router Address.
The default gateway is the IP address of your router.
This IP address of the router will be used to open the set up page of the router
Now you got the IP address of the router.Open the Internet Browser ( Internet Explorer, Firefox, Safari )
In the Address bar of the browser Type the IP address of the router.
Do not type http:// or www just type in the IP address only.
It will ask you for the user name and the password of the router.
This is the User name and the password of the router and NOT the wireless password. On a wireless router, there are 2 passwords. One is to access the router and the other one is for the wireless network.
For most of the routers the default password will be " admin " . for some routers the default password is " password ". For Linksys router the default password is admin and no user name.
Jan 23, 2011 | ASUS RTN10 wireless router
When i try to get in to my router set up by typing the ip address in to address bar, it wont let me in
To configure the D-Link router, you will next need to open a web browser and type
http://www.192.168.0.1
Dec 20, 2010 | Acer D-Link 2.4GHz Wireless Router 802.11b...
No admin web interface page after typing 192.168.1.1 in browser URL
To find the IP address of your router open a command prompt (Go to start -> Run), type "cmd" and hit "Enter".
In the following command window type "ipconfig /all" and hit "Enter" again. The value after "Default Gateway" is the IP address of your router.
Type that into your browser. Don't type www.etc., simply (in my case) "http://192.168.1.1".
If this doesn't work for you, go back to the command window and type "ping 192.168.1.1", where you replace the IP address (192.168.1.1) with the one you found under "Default Gateway". If you get a "Request timed out" reply, you have a connectivity problem.
In that case, come back here and post the output of the first command (ipconfig /all) as a comment. I will check back and we take it from there.
Aug 10, 2009 | Linksys Wireless-G WRT54GL Router
Cannot detect network connection
Instead of running the CD, try to configure the router manually. First, make sure that you have verified internet connectivity between your PC and your modem. Once verified, connect your modem to the internet port of your router and then your PC to any of the ports (1, 2, 3, or 4) at the back of your router. Turn ON your modem, router and PC.
On your PC go to Start>Run> then type "cmd" and hit the Enter key.
On the black screen type ipconfig/all and hit the Enter key.
Check the IP address of your Local Area Connection.
If it is 192.168.1.xxx, then you are good to go.
Check the connectivity between your PC and the router. On the black screen type ping 192.168.1.1 and hit the Enter key.
If you're getting replies, minimize the window and open a browser.
Type http://192.168.1.1 and hit the Enter key.
Once prompted with a username and password type admin (admin is the default password).
Once you're on the Web interface of the router, enter your internet connection type and then save the settings.
Once done, click on the Status tab and then check the internet IP address.
If there's an internet IP address, try to open a new window and see if you can access the internet.
Jul 03, 2009 | Linksys WRT160N Wireless Router
IP address
By visiting this http://www.ip-details.com/internet-speed-test/ you get your ip-address.
Mar 20, 2009 | Computers & Internet
How do I enable DMZ on the router?
1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, Firewall, enable it and click on apply. 3. Click on DMZ and select Yes to enable DMZ. 4. Enter the IP address of the machine, which was assigned a static ip address to be kept under DMZ, and click on apply.
Feb 19, 2006 | SMC Barricade 7004
Computers & Internet Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
