Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Tv turns on have picture then about 1-2 minutes later turns green then shuts off
  • Sony Master
  • 8,617 Answers
Very common issue indicating the Green CRT has shorted and will need replacement. You can get the Replacement Green CRT for your model from www.tvrepairworld.com they are listed under the Projection Tube CRT catagory
Posted on Feb 19, 2012
tvtechnician
  • 105 Answers
SOURCE: Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Posted on Oct 13, 2007
  • 84 Answers
Change the lamp
Posted on Jul 05, 2008
SOURCE: Sony Wega kdf-50E2000 Keeps turning off and on
Before you replace the lamp I recommend trying to clean/dust the lamp component and lamp plug in area. I had the same problem and was able to resolve it by simply blowing the dust off the lamp components and fan. Use a can of high pressure air to get into the cracks and crevices.
Posted on Feb 03, 2010
  • 129 Answers
SOURCE: The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Posted on Jul 28, 2010
smarthome2
  • 1114 Answers
SOURCE: Half the TV screen has
If your TV is a wide screen sony LCD, it's more than likely the optical block.
Here's a good post regarding all of sony's LCD problems fom 2003 to current
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-problems-by-TV-model
Hope this helps
Posted on Sep 20, 2010
Tv wont come on
first of all you may unplug about 2 hours and try again as symptom shows some internal overheating or power failure going on
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
My sony rear projection tv flickers green then shuts down ,any help
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
Jul 19, 2010 | Sony KP-57WS500 57" Rear Projection...
I've been having this problem for a while. when I'd turn the tv on I was able to watch it for about 15 minutes. suddenly the picture and voice would turn off, but the green power button was still solid...
Sounds like it may be a power supply issue. I don't know what "modules" the tech replaced, but I would have advised you to scrap the TV for a newer model as they can get pretty expensive to find and replace parts of the older rear projections. Sorry I can't be more help to you.
Feb 04, 2010 | Televison & Video
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
