Panasonic SA-PT650 turns on bit just says Initiating Please Wait, then nothing else. Won't even open the try.
5 Suggested Answers
SOURCE: Panasonic SA-HT692
Thanks for your help, but I couldn't wait any longer and took care of the problem. This is what I did to fix it: With the dvd player unplugged, I removed all the screws and opened up the dvd player to make sure that there was no dvd stuck inside. Once I confirmed that there were no obstructions, I then proceeded to plug in the dvd player so I can see how the player reacted to the error messages. I noticed that every time I pressed the eject button, the section where the sensor reads the disc was slightly moving but not fully reacting. So right above the laser sensor apparatus, there's a white plastic circular piece and I moved that around a few times and it did the trick. Problem solve, the dvd player is working like a champ. Hope this helps if someone out there that has the same problem.
Posted on Feb 13, 2008
SOURCE: Panasonic SA-HT700 Home Theatre - Tray won't open
i have the same issues. Just took a screw driver to the four sides and opened it up. Took 5 mintues. Pulled them out.
Posted on Jul 10, 2008
  • 208 Answers
SOURCE: Tray won't open!
Hi, not being too familiar with this model ( i.e. whether a single disc or 5 disc changer). it sounds like the CD player section is trying to find home position and will not continue until it has done so. It is very likely that there is a disc in the mechanism and depending how competent you are with a screwdriver, you may be able to release the disc either by removing the top cover or check on the underside of the machineto see if there is a hole in the bottom where you can wind the cd mechanism to the eject position.
Posted on Feb 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: Got F61 error on Panasonic SA-HT680 system. Now
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Aug 10, 2011
DVD changer is jammed on my Panasonic Sa-pt770 Receiver
if you have 2 tiny screw drivers, if not, the tips of a butter knife might be skinny enough, you can try to insert them a wee bit into both sides of the tray and pry outward, carefully of course, and unjam the tray
Mar 09, 2013 | Panasonic Sa-pt770 Receiver Only For...
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
PANASONIC SA-PT650
Most likely it is beyond repair if it got 220 volts.
Dec 04, 2012 | Audio Players & Recorders
MY PANASONIC SA-HT75 KEEPS ON CLICKING OFF WHEN I SWITH IT ON.WON'T START UP
There Panasonic SA-ht75 dvd Decreasing the opening treading on what's happening back immediately shuts down
Sep 05, 2011 | Panasonic SC-HT75 System
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
My Panasonic SA-PT875 surround sound system won't
Hi, I have the same issue ! ... Can you let me know if you fixed it please.
Regards Brad
Aug 16, 2011 | Panasonic Audio Players & Recorders
How to hook up external amp need to know how to run jacks to the amp and speakers which out put for amp to run the front speakers on a panasonic sa-he70
Manuals help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE70K-Receivers-manual/id/312ag701/t/2/
Not knowing anything about your 'external' amp or how you want it to function the only thing you could do is feed it the analog stereo output of the SA-HE70 from one of its OUTs (Tape or VCR). It won't be volumed-controlled by the SA-HE70.
Jun 01, 2011 | Panasonic SA-HE70 Receiver
"Please wait" ... panasonic dmr-e85h seems frozen
Have you tried unplugging it for a couple of minutes?
Aug 25, 2009 | Panasonic DMR-E85H DVD Recorder
Non Responsive Buttons
Hello..
Is this system one that has speaker connections?
If so, all the speakers must be connected for it to work right.
Apr 09, 2009 | Panasonic Electronics - Others
Dec 30, 2007 | Audio Players & Recorders
154 people viewed this question
 Grubhead
Grubhead
