Question about Video Cameras
Why wont my camera turn on
Its a CMOS DVH-A85 i just unpacked it, I charged the battery placed it in properly but it wont turn on. Thank You
markevans
  • 148 Answers
SOURCE: xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
Posted on Dec 24, 2007
SOURCE: FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
Posted on Oct 09, 2008
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
  • 36 Answers
SOURCE: after snorkeling camera wont work at all
The sad saga of buggered u/w cameras continues. Check the interior of your camera carefully for any sigh of salt which will look like white crusty deposits or resulting corrosion. If you find same, it a major repair or toss the camera. One must be *extremely* careful when cleaning the seals and closing up an underwater camera. The slightest contamination on the seals such as lint, a hair, a grain of sand or whatever, is all it takes.
Consider cameras used on or around or under salt water as an expendable item. Harsh but true in my long experience in U/W
photography. Was NOT much of a problem with w/ film cameras, but the modern electronic wonders are very delicate.
Posted on Aug 20, 2010
caroldon
  • 17130 Answers
SOURCE: 7 days ago i took my battery off to charge my
Please make sure that the battery is clean and also the terminals within are clean. If you had been using the camera prior to the charging then the camera must work unless if the battery was spoiled by wrong charging. If you can use a multimeter to check the voltage which must be as specified on the battery label. Now make sure that the battery gets good contacts into the camera when inserted. If this wont work then it possible that there are errors within the camera and you need help from the nearest Nikon center.click the link below
http://www.nikonusa.com/Service-And-Support/Product-Support.page
Posted on Mar 28, 2011
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Changed batteries, wont turn on.. Vivicam 5022
Welcome to FixYa.
1. Make sure that the battery meets the required battery type for your camera.
2. If you are using rechargeable battery, make sure it is charged properly.
3. The battery you newly bought might be defective. It happens once in a while specially if the battery is an old stock.
Thank you for using FixYa.
Jas247
Sep 24, 2011 | Vivitar Cameras
Will not stay on.. turns on and then beeps once and turns off.. the battery is fully charged
Welcome to FixYa.
There are three reasons why your camera power ceases while in use.
* The Battery is exhausted
- insert a charged battery or recharged the battery
* The camera is turned off automatically
- turn on the camera power again
* Operation has ceased in a low temperature outside of the camera usage temperature range
- make sure the camera and battery warm by placing them in your pocket, etc. and then immediately before shooting,place the battery in the camera and then shoot.
In your case, posible will be the 3rd reason. If you still having the same issue after doing the troubleshooting. I also suggest to removed and re-insert the battery and try to switch it on again.
If this option wont work, you have to contact your service center.
I will be more happy to know if my solution will help you or not on your issues on your camera.
Feel free to reply on this for any question or comments.
Apr 05, 2011 | Samsung TL 105 Digital Camera
Are the batteries fo Powershot A85 rechargeable
This camera takes ordinary AA batteries. You can use alkaline ones, which are mostly not rechargeable, or you can use a set of AA size NiMH rechargeable ones, which will last longer per charge than a set of alkalines. You will need a separate charger for the batteries, they won't charge in the camera. You can buy a charger complete with a set of batteries cheaply online or in shops. Get ones marked 2300 mAH or 2700 mAH if you can- they will last longer than ones with lower ratings.
Oct 18, 2010 | Canon PowerShot A85 Digital Camera
My camera wont turn on
Have you completely charged the camera? Try removing the battery and place it again closing the battery door properly. If its a Megapixel camera, attach the camera to your computer and see if you get MSDC on the LCD screen. Ask for a replacement only as the last alternative.
Sep 02, 2010 | Vivitar ViviCam 8025 Digital Camera
Photo has stripes
If your Canon A85 shows similar/ like to below image then its ccd imager chip failure problem and ccd imager will be replaced.
Canon offers free of cost ccd imager replacement for A85 camera.
Click Canon CCD Imager Advisory for details.
Thanks.
Dec 20, 2009 | Canon PowerShot A85 Digital Camera
Power Trouble
How to replace the CMOS battery. Like any battery the computer CMOS battery can fail or lose its charge.
No power or computer does not turn on. No power from the computer can be caused by any of the below possibilities. ... into the laptop you should see a power light or battery charge light.
How to replace the CMOS battery. Cause:. Like any battery the computer CMOS battery can fail or lose its charge. ... Most likely causes are bad power supply or bad motherboard.
Good Luck, Please dont for get to Vote.Thank you.
Dec 19, 2007 | Dell InspironTM 1501 Notebook
Canon a85 only works with no Memory Card.
Here are some simple things to try first for a camera that won't power on. Recommend trying the first step listed for the A520:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Nov 26, 2007 | Canon PowerShot A85 Digital Camera
Canon a85 unable to turn on
Here are some simple things to try first for a camera that won't power on:
Sep 20, 2007 | Canon PowerShot A85 Digital Camera
Canon a85 problem
Could be that the non-rechargeable batteries are blocking current from the rechargeable ones. Either get all rechargeable and charge them AT LEAST 14 hours before using, or use all alkaline - fresh. If the same display happens it could be a defective CCD which is being replaced FREE by Canon. Go here for details: http://www.imaging-resource.com/badccds.html
Nov 25, 2006 | Canon PowerShot A85 Digital Camera
Video Cameras Logo
20 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
