Question about Intel Motherboard
DISK BOOT FAILURE
MY INTEL DESCTOP BOARD D101GGC DOES NOT FIND SATA HARD DISK ,HARD DISK IS OK, PROBLEM WITH BOARD ,HELP ME
The sata cable\bus that connect the hard disk with the motherboard get loosen up some times. that results in the disk boot failure. if you once remove the sata cable from the harddisk and motherboard and then fix it tightly you can get the system working properly again. if the problem again persist then bye a new sata cable and fix it by replacing the older one, Thank You!
Posted on Oct 27, 2008
Hay, i just wanted to know wheather intel d101GGC supports ddr2 ram.and also needs to know wheather the board supports the sata harddisk
This motherboard does not support DDR2 RAM but this motherboard supports SATA hard disk
Reference: http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
You need to have adobe reader installed in your computer to read the pdf file from the link above
Nov 14, 2010 | Intel D101GGC Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Can i instal sata hard disk in intel desktop d101ggc
Yes, according to the manual the board has four SATA interfaces. SATA is backwards compatible, so the only risk is not to get the maximum speed. Be aware that if you are replacing a drive, the set up procedure might require initial drivers before setting up the OS. You will need also 1 piece of SATA cable, fout bolts for attaching the disk, and maybe a power adapter joint if the disk has just newer standard socket and your power supply does not have such jack. If you are installing the disk as a second drive for storage, the set up will be far more easy.
Nov 11, 2009 | Intel D101GGC Motherboard
Sata ports & mic is not detecting
Would help if you told us what the make and model of your motherboard is.
Mar 08, 2009 | Intel D101GGC Motherboard
BIOS ROM checksum error
have you a hard disk in the pc ?
somehow your hard disk has stopped booting (virus , bad hard disk boot sectors)
you may have to reinstall the OS
hope this helps
Jan 05, 2009 | Intel D101GGC Motherboard
Not able to install windows XP on sata hard disk having Intel d101 mother board. please help but not using F6 option as I don't ahve floppy disk drive on my system
You need to sliptream SATA drivers into your setup disk.
Download from here
http://driverpacks.net/DriverPacks/
driverpacks mass storage
copy windows CD to hard drive then use "Nlite" to insert them into the drivers section
then burn to a new CD.
and reboot from it should have no problem then
Dec 10, 2008 | Intel D101GGC Motherboard
Unable to install RHEL5 in D101GGC
http://www.linux.iastate.edu/rhel5/...READ THIS IT WILL SOLVE THE PROBLEM.RICHARDM69
Nov 07, 2008 | Intel D101GGC Motherboard
Intel Motherboard Logo
142 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
