Question about Sharp Office Equipment & Supplies
Replacement thermistor for sharp 8560
It seems that there are no longer replacement parts available from Sharp for this microwave thermistor. It's a very old unit built in the mid to late 80s, but in perfect condition other than this thermistor. What led me to this problem is that the microwave will operate for 2 minutes in convection mode then stop working. Pressing start again will get it going for another 2 minutes. The leads on the exposed side of the part are completely corroded on one side the actual component still registers on the ohmmeter. I thought about re-soldering the part, that will most likely not work given the high temps it's exposed to. Any advice for replacements? The original part number is:FHHZ0019WRE0, 5K based on the wiring diagram on the inside cover schematics.
  • 58 Answers
SOURCE: Mita DC-1205 Copier
If you need a manual for it try looking on line for older copiers. Since that unit was built back in the mid 80s.The other person that helped you on the toner is exactly right.
Posted on Oct 24, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Microwave Oven
Quite often this is due to grease or food particles stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
  • 61 Answers
SOURCE: How to locate and replace copier exhaust fan
Hi, H3 is abnormal high tempeature in the fuser. Never had issues with the fan, probably you have a 'melt down', inspect the fuser through the sprung loaded flap and see if the three picker fingers that rest on the roller are melted. If they are then you require a fuser rebuild to include both fuser rollers, fingers, bearings and thermal fuse.
Cheers
Andy
Posted on Feb 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
Posted on May 09, 2008
  • 110 Answers
SOURCE: Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
Posted on May 30, 2008
Sharp microwave oven flashes 88:88 touch pad does not respond , model R-9H20
You have a failed membrane keypad.
Replacement keypads are no longer available for any Sharp R-9H-series microwave ovens.
The oven will have to be replaced.
Nov 19, 2016 | Sharp Microwave Ovens
I am looking for someone to fix a Sharp Carousel Convection & Microwave Oven (Model R-8560)?
Make some phone calls locally we have no idea what is locally available to you
Sep 06, 2016 | Sharp Microwave Ovens
I need a manual for sharp model r-303cw
I haven't found the instruction manual available as a free download online. However, there are several places to buy a copy. Sears Parts Direct has a printed copy for sale for $4.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R303CW/0958/0123245/50022360/00001?blt=06&prst=&shdMod= . The current part number is IB-R303CK. Searching for the part number gave several other sites with the manual available.
The Sharp R-308K is a very similar microwave and that manual is available as a free download. See http://www.managemylife.com/mmh/owner_manuals/7167/SHARP-Countertop-Microwave-L0906397?brand_name_search=Sharp+microwave .
I hope this helps.
Oct 09, 2011 | Sharp R-303CW Convection / Microwave Oven
We have a sharp r-9h84b convection microwave and the carosel has stopped working when the tray is in place. Any thoughts the carrosel seems to rotate very slowly when there is nothing on it.
It's almost certainly a bad turntable motor.
The part number was RMOTDA079WRE0 but it is listed as no longer available.
In some cases, older microwaves are available locally at repair shops or on Craig's List.
If you want to keep your eyes open, this same motor was used in the following Sharp models:
R9A20
R9A50
R9H11
R9H60
R9H66
R9H71
R9H73
R9H76
R9H80
R9H81
R9H81B
R9H83
R9H84
R9H84B
R9H91
R9H91B
R9H93
R9H94
R9H94B
Good luck.
May 23, 2010 | Sharp R-9H84B Microwave Oven
I have a Sharp micro wave model R-1492. It turns on, but nothing cooks. Do you think I may need to replace the magnatron
first before you replace the most expensive part of the unit,check the h.v. diode and h.v. capacitor, the thermistor on the magnetron tubes outer case side, you will need to remove the top cover to accomplish these things
Nov 14, 2009 | Sharp R-1492 Microwave Oven
Sharp R-930 not heating up to temperature
It may be the thermistor, heating element, etc.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The manual has complete disassembly, test and part replacement info, as well as a very good troubleshooting chart.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Dec 05, 2008 | Sharp R-930AK Convection/Microwave Oven
Need part #, price & availability of a replacement "touch" key pad for Sharp model R-9H91
The keypads for all Sharp R-9H## models are no longer available.
Once the oven becomes impossible to use, it will have to be scrapped.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Sharp Microwave Ovens
R-9h81 sharp microwave oven
Replacement keypads for the R-9H-series of microwave ovens are no longer available.
So for as long as you can get by with the oven like it is, go ahead, but the only solution id to replace it with a new model.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online for current equivalent models.
Sorry I can't bring better news.
Jul 08, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
