Question about Corel WordPerfect Lightning
This file is password protected
Downloaded a IRS file. Tried to open but "This fie is password protected" message was displayed.
PDF file corrupt, how to repair it?
There is a universal solution of your problem: PDF Repair Toolbox - The tool reads corrupted PDF files and saves all recovered information to a new file for Adobe Reader/Adobe Acrobat.
Mar 19, 2016 | Microsoft Office Professional 2007 Full...
Tip
How to Open a Password Protected Word 2003 Document?
Microsoft Word document offer password protection which allows you to protect your sensitive information containing in your Word file, then anyone who wish to access to your file should enter the correct alpha-numeric password firstly. If you cannot open a secured word 2003 document, it must be irritating, right? This article will show you three effective options to <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"><u>open a password protected word 2003 document</u></a>.<br /> <br /> <img src="open-password-protected-word-document.jpg" /><br /> <b><br /> <br /> Method 1: Using VB.NET<br /> </b><br /> <br /> The following code sample shows how to open a password protected word document using VB.NET<br /> <br /> [VB.NET CODE STARTS]<br /> Dim objWord As Object<br /> Dim strPassword as string = "PASSWORD"<br /> <br /> objWord = CreateObject("Word.Application")<br /> objWord.visible = False<br /> objWord.application.WindowState = 2<br /> objWord.application.DisplayAlerts = False<br /> <br /> Try<br /> objWord.Documents.Open("YOUR DOCUMENT FULL PATH NAME", PasswordDocument:=strPassword )<br /> Catch ex As Exception<br /> Msgbox ("Cannot open word document" ,vbExclamation , "Password Protected")<br /> End Try<br /> [VB.NET CODE ENDS]<br /> <br /> <br /> <b>Method 2: Obtain the password from the source</b><br /> <br /> <br /> The following steps sample shows how to obtain the password from the source<br /> Step 1: Check with the word document source for the password.<br /> Ask yourself where does the locked word 2003 document come from? Supposing it created by someone else, then ask the creator for the password. If your own are the word document source, you will need to locate the lost password.<br /> Step 2: Verify the password with the source.<br /> Make sure you have the right password on hand. Verify the password can save you time. The other reason to do so is that you never know they might have given you the wrong password in the first place.<br /> Step 3: Enter the correct password.<br /> Type in the correct password at the "Enter Password To Open File" dialog box. After you have entered the password, click the OK button.<br /> <br /> <b><br /> Method 3: Using password-cracking software</b><br /> <br /> <br /> If so far you still didn't solve your problem, then you'll have to go buy one of password-cracking software available for this purpose. So go to the link in "Source(s)" and download the <a href="http://www.recoverlostpassword.com/products/wordpasswordrecovery.html">word password cracker</a> program. It comes with a trial version and follows the walk through. You only need to use the program to open the locked word document, choose the type of attacks for word document with strong encryption. Then the program will start and keep running until find out the lost word password for you to open.<br /> Source(s):Good Search: <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html">SmartKey Word Password Recovery<br /> </a><br /> <br /> Keep in mind that there nothing will miss as long as you use the corresponding password to<a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"> <u>open your password protected word document</u></a>. <br /> <br /> Article Source:<a href="http://recoverlostpassword.com/article/open-password-protected-word-2003-document.html">http://www.recoverlostpassword.com/article/open-password-protected-word-2003-document.html</a> <br />
on Apr 15, 2011 | Computers & Internet
Tip
How To Password Protect & Decrypt Microsoft Office 2010 Documents
Microsoft office 2010 , the next big buzz from Microsoft after Windows 7, is a productivity suite for Microsoft Windows,and the successor to Microsoft Office 2007.
Screenshots of Microsoft Office 2010
Not long ago I was just wrote an article about How to Password Protect Microsoft Office 2007 Documents. Now I’ll write a similar article about office 2010 by popular demand.
Microsoft Office 2010 indeed simplified the process to password protect and encrypt office documents. Which was considered a commendable improvement over password protecting documents under Office 2007. as the new process for Office 2010 is consistent across the core Office product line which including Word 2010, Excel 2010, PowerPoint 2010 etc. so here I only need to show you how the process just once using Microsoft Word 2010 as example.
Follow the step-to-step guide To Protect A Word 2010 Document Using Built-in Password Encryption
1. Click the File tab, then Click Info. On the menu to the right Click Protect Document and
Click Encrypt with Password.
2. The Encrypt Document dialog will appear, Type in a password and then Click OK to finish.
Please note – It’s very important to use a STRONG Password or Pass Phrase to protect your word document. Using a long PASS PHRASE (IE:I enjoyed myself today!) however with 10 or more characters will significantly increase the encryption strength of the document and decrease the likelihood someone will be able to break the encryption and gain access to your document.
After setting a password, your document should be protected!
Having password protected your word document? Someone should ask what if I forgot the password. So that’s what I’ll show below.
Follow the step-to-step guide To decrypt Word 2010 Document Using word password recovery 5.0
With this user guide, even a new user can fully control Word Password Recovery 5.0 in less than a minute.
Step1: Click “File>Open” in the Menu or the “Open” button to browse in the Word document.
Select your file in the Open File window, and click “Open“.
Step2: Select “Brute-force Attack (Trying All Possible Combinations)“.
Step3: Click “Start” button in the Menu to initiate the program.
Step4: The program is searching the password. Some time later, a message box pops up to you, displaying the expected password. Click “Remove All Passwords from the File” to remove all passwords (Password to Open and Password to Edit) from the file. Click “OK“.
Following this article, you could password protected your office 2010 and decrypt password protected office 2010 with ease.
on Jun 30, 2010 | Computers & Internet
How do I remove "write protection" from Word files
  1. Open Word, and open the protected document. Click on the "Developer" tab.
  2. Click on "Protect Document" tab, and then click on "Restrict Formatting and Editing."
  3. Click on "Stop Protection."
  4. Type the password into the password box.
If you have forgotten the password, copy and paste the information from the write-protected Word document into a new Word document, and then save it under a different name.
I do this for fun & 4 thumb feed back, not $$$$
Jim
Oct 04, 2011 | HP Computers & Internet
Tip
How to use Zip files password recovery Tool to crack Zip files password
We came into contact with Zip/WinZip files or Rar/WinRar files so often, naturally,we need to face with a trouble - if this Zip/WinZip files are passwords protected, then questions come, how can i open the password protected Zip files.Here what i mentioned is how to crack Zip/WinZip files with passwords.
Its to use Zip files password recovery tool.You can go and see the Key features of Zip files password recvoery tool.It supports for all WinZip/Zip files.
4 easy steps with several mouse-clicking to get you used to the program to recover password for WinZIP/ZIP files!
Tip: This is a concise guide for you to quickly experience the program. For the detailed information, please refer to the "Help" file integrated in the program. On the program, click "Help" in the Menu will be OK.
Step1: Click "File>Open" in the Menu or the "Open" button to browse the WinZIP/ZIP file in.
zip-files-password-recovery-01.gif Select your file in the Open File window, and click "Open".
zip-files-password-recovery-02.gif Step2: Select "Brute-force Attack (Trying All Possible Combinations)".
zip-files-password-recovery-03.gif Step3: Click "Start" button to initiate the program.
zip-files-password-recovery-04.gif Step4: The program is processing for the password. Sometime later, a message box pops up to you, displaying the expected password. Click "OK".
zip-files-password-recovery-05.gif So,your Zip/WinZip files with password is shown by this Zip files password recovery tool, you can so easy to open passwords protected Zip files.Go to the password recovery official site see ditails or other tools.
Other metioned article:Four methods for you to recover windows adminnistrator password
keywords:
zip files password recovery,zip files password protected,crack zip files password,open passwords protected zip files
anchor text:
summary:
We are so often to contact with Zip files password protected,if we want to open the passwords protected Zip files,how to do? Here is a methord to crack zip files password,by using zip file password recovery tool,easy with 4 steps.
on Apr 22, 2010 | Computers & Internet
Hello: I have Adobe Photoshop Elements 6.0,Windows XP with Pentium 2.8Gz and 1.59RAM. I set off on a mission to organize family pics but Photoshop Elements is driving me crazy due to several...
whats Graffi\'s automatic program, it sound like this program is incompatible with adobe photoshop elements. what format wereyour original files before you opened them in phtotoshop elements?
Feb 02, 2011 | Adobe Photoshop Elements 6: Windows
Hi. I have a Godrej make e-swipe safe (locker). It has been functioning alright. But recently even after correctly giving the 4 digit password, the display says 'OPEN' and after 3 secs 4or5 beeps given...
i have a godrej locker at home , but i locked it twice and now the message comes secure . now how do i open it. the code is same but it was locked twice and so the message came as secure - good.
now i can't open it
Feb 01, 2011 | Safe International Digital Electronic Safe...
Have a excel password protected file. have forget my password. help me in opening my file
How to Crack Excel Spreadsheet Passwords by Petri IT Knowledgebase Team - January 8, 2009 Often when an employee departs, they take important Excel passwords with them. This guide outlines how to use a simple Excel password recovery application to crack lost or forgotten passwords, allowing you to unlock password-encrypted Microsoft Excel documents quickly as possible.
Step 1: Download and Install the Office Password Recovery Utility To perform the following recovery steps, you'll need to grab the download of Office Password Recovery Pro, available directly here. (2.1Mb)
Once you've downloaded the program, run the install with the default options.
Step 2: Navigate to the Protected File and Begin the Recovery Process Click the Open button on the top left, navigate to the protected spreadsheet file:
May 09, 2009 | Computers & Internet
Sir i gave password for my nokia 3230 mmc memory card to protect against illegal use. but unfortunately i dont remember the password,so I am unable to use my memory card. please help me unlock it
Install and launch MMCPWD application. It will display some special characters including your password.
Option 2:
Locate mmcstore file. Install and launch System Explorer or FExplorer application. Go to c:\system\ and open (using unicode/hex editor) the mmcstore file. it will display your password. NOTE: you can also copy the mmcstore file to any folder of your phone memory, rename it to mmcstore.txt and open it without using any unicode/hex editor).
Option 3:
1. Open up fe explorer thingy.
2. Go to C:\system\ folder and locate a file called mmcStore. Scroll down till you find it.
3. Copy it to C:\nokia\others
4. Highlight it
5. Click options
6. FILE>RENAME
7. IT should turn blue: right click then write ".txt" (should look like "MMCSTORE.txt"
8. Try to open it, (that should be your password, if nothing happens then go to 9.)
9. Connect phone to pc
10. Open the file from C:\NOKIA\OTHERS\MMCSTORE
11. Copy the file to your desktop
12. Open with Windows notepad/ microsoft word
13. That should be your password
May 06, 2009 | Nokia 3230
Computers & Internet Logo
203 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
