Question about Honeywell Programmable Thermostat Heater
HONEYWELL CM921 ROOM THERMOSTAT
I AM TRYING TO SET THE TIMES FOR MY CENTRAL HEATING TO COME ON BUT HOW DO I SET IT SO THAT IT COMES OFF WITHIN A COUPLE OF HOURS, RATHER THAN STAYING ON ALL DAY
  • dyloconz Dec 15, 2008
    the programme instructions say that the temperature changes can be set between 3.00am and 2.50am - so what happens in that 10 minute period between 2.50 and 3.00am?
  • mark67123 Jan 14, 2009
    Sounds like a similar problem:
    The programmer/timer function on our Honeywell CM921 Wireless Programmable Room Thermostat does not work properly.
    Regardless of the time settings, the heating fails to come on or go off at the correct times set in the programme. For example, if the programme is set to come on at 0630 and go off at 0800, it does not necessarily come on at 0630, it basically comes on whenever it wants. Also, it will not switch off at 0800 and would stay on all day until switched off manually.
    In other words, manually switching on or off is the only way we can control the time the heating operates.
    Any suggestions please?
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Posted on Oct 27, 2008
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
I have the same problem where my honeywell cm921 room thermostat never turns off the central heating. If I set my off temp really low will this solve the problem, but if its really low does this become the...
It's either because the thermo sensor is faulty or the location is wrong. Try setting the temp one degree above room temp and see if that works, if it does it's a location issue. The thermo should be close to the centre of the house, not near an outlet or the RA vent & not in a breezeway or other heatsink, at approx 1.5m above floor level.
Dec 14, 2010 | Honeywell Programmable Thermostat Heater
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat CM921, how to set the heating for a 6.30am??
if you have a programable tstat you need to go through the settings for each day and time. usually the buttton will say prgm or program sometimes it will be set try to get into the settings menue and then you can adjust times
Sep 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,989 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
