Question about Siemens 200 Amp Main Breaker 30 Spaces 40 Circuits
Siemens ite g3040mb1200 bus swap with a g3030mb1200
I have a 3030. Can I swap out the bus in the existing enclosure to a 3040 bus and use tandems for 4 more circuits? Dont want to remove/replace the can. Planning on killing the main, and swapping bus and breakers. (licenced JW)
  • G Bwire Apr 07, 2012
    Thanks, I went with a new sub panel.
  • Siemens Master
  • 3,287 Answers
While this may appear to be doable - the fact remains that the interior and enclosure are tested, approved and listed by UL / FM / etc. as an entire assembly. Taking from one and replacing with another results in a combination that was not listed.
If however, the enclosures of the two panels are identical - then I suppose I would consider doing the same thing. I would be sure to change out the panel cover so that the cat number and info matches the bus.
Posted on Apr 04, 2012
2 Suggested Answers
  • 122 Answers
SOURCE: Will a Siemens ITE
yes it will, you need to always make sure that you put the same brand in the panel box, good luck
Posted on Sep 18, 2011
What are the circuit breaker part numbers for a Siemens Ite G3030MB1200 Panel
Go to any home store and ask them, they will have the breaker or one to use as a replacement
Sep 04, 2014 | Siemens Electrical Supplies
Application
Use siemens for old ITE breaker box.
Square D will not work:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe product, and attach photos.
May 26, 2013 | Square D Co. HOM130C Circuit Breaker
ITE Imperial EQ8S&F panel.
well only one due to insurance ITE, but there are 3 others that would work in a bind.Siemens,Westinghouse, and Cutler hammer.
Jan 19, 2013 | Electrical Supplies
Can I use siemens tandem qt breaker in g3030mb1200 panel
No. your panel is designed for full size circuit breakers. Check the label inside the panel and it will tell you what style circuit breakers are allowed.
Aug 05, 2012 | Siemens Ite Twin Q1515 Circuit Breaker...
Will a Siemens ITE Q1515 15 amp tandem breaker fit into a 200amp Siemens Series E panel G4040ml1200?
Sep 18, 2011 | Siemens Ite Twin Q1515 Circuit Breaker...
I have an ITE breaker panel (G2020MB1100) with Q115 breakers, but need to add a 15 amp circuit. Will a Q1515NC fit into one of the Q115 slots?
Yes they will fit. They are both a single pole breaker. Turn the breakers over. They should look the same and snap into a single slot in the panel the same.
Not sure what you mean by No Clip? A Square D QO Breaker has a metal clip that snaps into the panel on the breaker mount and one on the Bus Bar.
Feb 22, 2011 | Siemens Q1515NC Circuit Breaker Two1Poles...
There was no grond bus installed
You can buy ground busbar at home center or electric supply and install in main box.
Or go back to seller and swap out for new box that is complete.
Feb 16, 2011 | Siemens Murray 125 Amp Circuit Breaker...
I have a 30space 200A load center from Homeline, and I have a tandem 20A breaker with the model HOMT2020. It will not lock in. the buss clip fits but the plastic case where the cut is to recieve the bus...
There are several variations even within brands. When in doubt, remove an existing breaker and take it to the hardware store with you to match the format. That way you get the right one in one trip.
Regards, Farmerbear
Sep 10, 2010 | Your One Source Square D #HOME250SPA 50A...
How can I replace my 30GB ultra ATA EIDE HDD with
Purchase a solid state drive, 2.5" for laptops 3.5" for desktops (or use an adapter for notebook drives with a 2.5")
Connect your IDE cable (and power cable on desktops) to the drive, install Windows and you are done!
If you want to keep your existing data, get an external enclosure for the appropriate sized disk and use a program like Norton Ghost or Acronis True Image to clone the existing drive to the new one, then swap the two drives (SSD from enclosure to internal, other drive out to enclosure)
Comment if you need more information!
Feb 06, 2010 | HP 100GB Ultra ATA/100 EIDE hard drive -...
Siemens 200 Amp Main Breaker 30 Spaces 40 Circuits Logo
804 people viewed this question
Top Siemens Electrical Supplies Experts
Steve
john h
Mike
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
