Question about Husqvarna Garden
Ran over a steel stake that locked up the blades and killed the engine.
Removed jam, everything free, but engine will not start. Is there a safety reset?
    Sergeant:
  • 316 Answers
Hello ben, Again,i said that the key way on the fly wheel may be out of time so engine will not start, you could check the deck safety switch may have knocked out or adjustment,hope this helps.
Posted on Feb 20, 2012
I ran over a steel stake that locked up my blades and killed the engine. Freed jam, engine will still not start. Is there a safety reset?
hello,check the key way on the flywheel,when engine is stoped suddenely this will happen,shears the keyway and throws out of time,want start,hope this helps,
Feb 18, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower starts but shuts off when put in gear or engage blades
Sounds like a safety switch is bad. The most likely culprit is the seat switch, which detects operator presence. If the switch is bad it will not detect an operator in the seat which will kill the engine if a gear is selected or the blades are engaged. It is located under the seat and easy to replace. Start there and let me know, Daniel.
Sep 20, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Replace switches & clutch. When brake is release everything dies. Ineed a wiring diagram.
There are a few safety switches on a riding mower. One is the brake clutch, which must be engaged to start mower if not in neutral for a manual transaxle. Another is a blade engaged safety that will not allow you to start it with the blades engaged and the other is the seat safety that prevents starting if the brake is not engaged.
If the seat safety switch is messed up and you release the brake it will kill the engine. I would start there.
I hope this helps get you going.
Aug 03, 2011 | Garden
Every time I use the lever to get the blades started it kills the engine. it does it even after i removed the belt. what is causing the blade rotation lever to kill the engine?
hi there talane
sounds like you have a safety switch problem
try disconnecting seat switch and retry if works could be wire grounding some where or faulty switch then try fitting a jump wire to seat switch wire connector then retry then check blade engagement switch may be playing up or a nuetral switch playing up but more likely a seat switch
with operator off seat and park brake on engine runs, but with pk brake off and operator off seat
engine stops , same if operator leaves seat and blades engages -engine stops,
if unit not in nuetral and pk brake not on unit wont start
take look
hope it helps
cheers pauly46
Jul 03, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 46"lawn tractor murray,when i engage the
I would start by splitting the systems. remove the ground wire that goes to the spark plug coil kill wire.
If the engine runs with the blades on then, the problem is in the chasis or safety switches. if you still have the problem it is the engine. Maybe the engine can not produce enough power to spin the blades.
This could be because of the common deck spindle bearing lock up or the engine being worn out.
After you do the test if you need parts contact a shop like www.arcolawn.com and they can ship you the parts.
Cheers
Joe
Feb 10, 2011 | Garden
My tractor keeps shutting off when i engage the mower blades
It would depend on what model, but could either be a deck drive problem or safety switch. With tractor off, I'd check the blades for free movement with no binding. If this is ok, then I would suspect the seat switch. The mower will not run with the deck engaged, and no operator present. It could be the seat switch is not making, so when you engage the deck it kills the motor. Test switch
Aug 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Engaging blades kills engine
there is a safety switch somewhere toward the bottom of the engagement handle if this switch is bad it will kill the engine there is also a switch under the seat that could be bad
Aug 23, 2009 | Garden
Started up...then died as if safety switch 18HP craftsman rider
On later models there are possibly three safety switches, one under the seat, one for the blade engage mechanism or blade clutch so the blades don't turn when the mower is started, and a neutral safety switch to make sure the mower is in neutral before it starts.
Jul 07, 2009 | Garden
Garden Logo
70 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
