Question about Troy-Bilt Garden
What kind of oil for tb 525 es weed eater - Troy-Bilt Garden
5 Suggested Answers
  • 7 Answers
SOURCE: weed eater runns great while at idle but not under trottle
When is the last time you changed the air filter?
Posted on Jun 26, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
  • 53 Answers
SOURCE: weed eater bogs down
Under what conditions does it bog down? When it just idles? Cold or hot? When you give it gas? When you try to cut?
Posted on May 11, 2010
SOURCE: What is proper gas/oil fuel ratio for TORO Model
50:1
Posted on Jul 02, 2010
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed eater 961380017 where is oil drain plug located?
On the Weed Eater 961380017 it uses a Rato engine and the mower is made by Husqvarna, it is the same as their U.S. model 5521P. To drain the oil you have to first remove the dip stick and then tilt the mower over to drain the oil out into a pan.
Aug 04, 2011 | Garden
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I need to know what kind of oil to put in my troy-bilt 4 cycle weed eater. I think the model num. is TB525CS, it's on the front of the weed eater right under 4 cycle.
Hi jo6616...
Use a good grade of 10W30 non-detergent oil in your weedeater.
Free answer....Please take time to rate me
May 30, 2011 | Troy Garden
25cc Weed Eater
Yes. any 2 cycle oil will do. It is right do not use marine oil it runs alot thicker than 2 cycle oil.
Jul 06, 2010 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
gasoline. Before operation, gasoline must be
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Garden Logo
132 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
