Question about Hayward H-series Electronic Gas Pool Heater H400
What does error code CE mean? - Hayward H-series Electronic Gas Pool Heater H400
    Scholar:
    New Friend:
  • 66 Answers
It means Communication Error. The display board and the Ignition board are not communicating with each other. Look for rodent damage first. If not that it could be either board and the only way to determine which one is by replacing one and see if it fixes the issue. Due to he cost of the boards it usually pays for itself to call a Hayward certified repairman out as he/she will have both boards available to try ond only replace the one you need.
Posted on Feb 18, 2012
Error code CE - 3316 - 4 for The Last of Us Remastered
connection error 3316 u have to reset your ps4 controller . on the back there should be a small hole that u can insert a needle through then reset it then connect it through wire and it should work fine.
Jun 12, 2016 | Sony PlayStation 4
I have a frigidaire refrigerator with electronic screen about a wk ago started beeping giving me a code of sy ce what does this mean?
Thank you for your inquiry, Carlos!
From the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and you would like to know the meaning. The error code "SY CE" stands for communication error at power up. This could be an issue with your wiring harness, main control board, or user interface board. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
May 26, 2015 | Frigidaire Refrigerators
Code on door of French door reads error message 5y ce. sounds like it is still running but no light inside or ice maker not working.
Thank you for your post, Carol!
I understand that your Frigidaire refrigerator is displaying an error code of "5Y CE". However it appears that "5Y CE" is an invalid error code. I have noticed the code of "SY CE" and that means there is a communication error at power up. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue it could be possible that there is an issue with your main control board, wiring harness, or user interface board. I would then suggest having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
May 19, 2015 | Frigidaire Refrigerators
What is the problem with my washer whan it has an erorr code CE ?
You have to tell us make and model to get a precise answer.
On many washing machines CE means communications error which is either a failure of the control board or some item controlled by the control board. It may be time to call the repair man.
Apr 18, 2015 | Washing Machines
I have a Frigidaire Gallery refrigerator model no, FGHS2679KE0 on the temperature control panel the display reads 5Y CE and the alarm is on what does this mean
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
Error code CE
"CE" error mean you have a communication error at power up. Check wiring between Main Control Board and User Interface Board. Replace User Interface Board. If problem still exist, replace Main Control Board. Good luck
Sep 09, 2012 | Electrolux Refrigerators
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Mar 28, 2009 | Frigidaire Freezers
CE-02 error code when scanning on SHARP MX-M550U copier
ce error means not hooked up property to your email server
Feb 12, 2009 | Office Equipment & Supplies
Kenmore Elite Top Loader "CE" error code.
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Hayward H-series Electronic Gas Pool Heater H400 Logo
237 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
