Pnc-1000 roland plotter, now say wrong parameters, keeps going on it's own
Have a roland pnc-1000 serial # zb25329 desk top plotter, all of a sudden it says wrong parameters, keeps going all over the place, as soon as I plug into computer, and not even in any program, just runs for hours, non stop,
4 Suggested Answers
fwadley
  • 482 Answers
SOURCE: need a driver for roland color camm pnc-5000
only works with 95,98,xp, I am looking for 1 of these for parts if you want to sale it let me know. Thanks farrenwadley@sbcglobal.net
Posted on Aug 19, 2010
  • 6771 Answers
SOURCE: my Roland camm-1 pnc-1100 was
No it will not work with XP windows or higher, because this system is using an out dated window system that goes back to the early nineties, and to my knowledge there is no driver available to run it with the current window system.
Posted on Jan 23, 2011
  • 63 Answers
SOURCE: My computer has died and
You can access them from this page: http://support.rolanddga.com/_layouts/rolandreports/_productsupportsearch.aspx If you are using XP or later you can download directly from here http://support.rolanddga.com/docs/Documents/departments/Technical%20Services/Downloads/d029270j.exe Best Wishes!
Posted on Mar 29, 2011
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
My roland pnc 900 keeps blowing the fuse can it be fixed
YES, CHECK YOUR SENSOR IT MIGHT BE THE PROBLEM.
Mar 23, 2011 | Roland Music
I wish to know how to open a Roland JUNO-D synth to access the little rubber strips with the key contacts; I have the typical key-not-sounding problem.
Usually there are a number of screws from the bottom to remove. SOmetimes they hide some under a label or rubber feet. The top should remove and pone must be careful of the cables from teh top to the base of the unit.
Keep track of where screws go as often they have different length and using the wrong length when re-assmbling caan cause trouble.
Aug 07, 2010 | Roland JUNO-D Synthesizer
When i turn ON the ROLAND-CJ 500, in the little screen will appear, "TEMPERATURE IS TOO LOW"...?
could you fix your roland plotter, because appears the same in my screen temperature is too low even is not, how can you fix this problem thanks
Aug 03, 2010 | Office Equipment & Supplies
Please i have a roland pnc - 2300 to engrave gold peices
please i have a roland pnc - 2300 to engrave pices of gold the program software i use is called ( ats graphic suite version 1.02) when i want to start engrave i click file engrave and give the order but the printer didn't begin the engrave there was inside the folder printers a file called cut script i didn't find it and the roland didn't start engrave can you help me my email is flexoart1@gmail.com
Regards Saleem Tahir
Mar 11, 2009 | Microsoft Computers & Internet
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland VS 2480
Press the "UTILITY" button under the Menu heading above the 10 digit key-pad. Under "System Parameter" -Param3, check that PS2 Mouse is set to "ON" and (of course) that the connector is firmly inserted into the mouse connector socket.
May 13, 2008 | Audio Players & Recorders
125 people viewed this question
jasbo
jasbo
