How do I restart my Kindle? - Computers & Internet
    Top Expert:
  • 1,575 Answers
Hi
Home >menu >settings >menu and the select on 'restart.
Hope it helps.
Posted on Feb 19, 2012
Reset a kendle
There is restarting a kindle versus resetting a kindle.
Quick Fix Restart Your Kindle 5th Generation
Reset Your Kindle
Aug 22, 2017 | Cell Phones
Tip
How to reset the Amazon Kindle (useful when the unit is frozen)
Hi.
The Amazon Kindle is known for having several firmware issues, and it is not unusual seeing the unit freezing and not starting.
To start you can attempt doing a soft reset. To do a soft reset press and hold the <ALT>, <Shift>, and <R> keys simultaneously. The Kindle display should go blank for few seconds, and then restart.
If your Amazon kindle is still frozen, try resetting the unit to factory default settings with the hard reset procedure below. Procedure is different, depending on the Kindle model.
All you have to do to reset the Amazon Kindle 2 and Kindle DX is pressing and holding down the power button for about twenty seconds, then release the button and let the unit restart.
If instead you have the previous model, the amazon Kindle one, then you will need to open the back cover by pressing it and sliding it to the right with your finger, same as when you have to replace the batteries.
Behind the cover you will see the reset hole switch.
Push and hold a sharp pointed object, like a paper clip, or the tip of a pencil inside the hole button located under the battery cover.
Wait about ten seconds until the Kindle restarts and resets to default settings.
The last procedure and the picture below refer to Kindle one only. If you have kindle two, then please use the first procedure.
If the above does not fix the problem, then the unit is faulty. In that case contact Amazon to get support.
Regards.
on Feb 21, 2010 | Amazon Kindle Wireless Reading Device
After charging overnight I only have a white screen when I switch it on
Try this suggestion rom Amazon:
Restart your Kindle Paperwhite
Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation).
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart.
Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Sep 07, 2016 | Amazon Kindle Paperwhite
How do I get out of Safe Mode?
Hi Claudia. I found this.
I found Please remove leather case on your kindle before performing the steps below.
Please press and hold down the power button for 25-30 seconds until the Kindle restarts or Shutdown. If it prompts for Shutdown then please shut down the device and power it back on.
That should fix the problem.
If the answer to your question was informative and helpful, please show your appreciation for my efforts by clicking the green Accept Answer button right below my first response.
Thank you for choosing Experthelp.
Safe mode turns on when you shut down the kindle while the volume button is being pressed down. Solution-Restart your kindle by holding the power button until the screen shuts off. Make sure that the volume button is not being pressed while you restart your kindle. Then keep pressing the volume button, about 10 times to unstick them then turn on the kindle. Safe mode should turn offand how you go into it.
and I found this
Jan 17, 2016 | Amazon Kindle Fire HD
I thought I deregistered it and gave it to my daughter but my name keeps showing up and it wont let her register under another name.
How to reset / restart your Kindle - YouTube
? 1:42
www.youtube.com/watch?v=XXj8PuYYY4Y
Feb 4, 2013 - Uploaded by Pieter De Waal How to reset / restart your Kindle. ... It won't reset or anything. .... Amazon Kindle 3 3G/GSM/WiFi 6" TEARDOWN - EEVblog #109 - Duration: ...
Oct 03, 2015 | Amazon Kindle 3G
My kindle won't connect to my wifi
Try restarting your kindle and access point, followed by restarting your kindle again and try connecting. This method might solve your issue.
Aug 14, 2015 | Amazon Kindle Paperwhite
How do I reset my first generation Kindle Fire and where is the reset button
Restarting Kindle Fire may resolve intermittent issues like a frozen screen, battery issues or trouble downloading content to your Kindle Fire.
To restart your Kindle Fire, press and hold the power button for 40 seconds and then release. After the device has completely turned off, press the power button to restart your Kindle Fire.
If your Kindle Fire is still unresponsive, try charging your Kindle Fire before trying to restart the device again.
Make sure you have the latest software version available installed on your Kindle Fire. The latest version is available at www.amazon.com/kindlesoftwareupdates
Mar 01, 2015 | Tablets & eReaders
Kindle wont restart
This may or may not work. Hook up the Kindle to the charger. This might start it up.
Feb 28, 2014 | Amazon Kindle Wireless Reading Device
How do I reset kindle?
  1. Restart your Kindle by pressing and holding the power switch for 20 seconds. Release the power button. The restart screen will appear.
  2. If Kindle is still unresponsive, try charging Kindle before resetting the device once again.
Aug 16, 2012 | Amazon Kindle 1
My Kindle says Critical Battery & I have plugged it in overnite & it still says this but I have it on the computer now & the light is on on the on switch so not sure what this means? is it...
Hi!
You can try these steps to solve this problem:
1. Connect Kindle to a different USB.
2. Verify the charge light at the base of the Kindle is on.
3. Restart Kindle by pressing Home > Menu > Settings > Menu and select "Restart."
4. Leave the unit charging for 30 minutes
If the problem persist, contact Kindle for repair options.
eBookBoy
Jul 09, 2011 | Amazon Kindle Wireless Reading Device
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
