Question about NetGear WGR614 Wireless Router
Wrt120n how do i set this up
  • NetGear Master
  • 32,281 Answers
If you need to reset this Netgear back to the factory defaults then to RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash.
THEN
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Feb 19, 2012
How do I find network key for wrt120n router
You will need to check the setting of your wireless router.
Do you have any computer connected to the network?
Using one computer connected to the network, you can open the router page and check the wireless router settings.
Check this link for Linksys WRT120N router setup and troubleshooting
Oct 15, 2014 | Linksys WRT120N Router
Duplex settings.
under IP settings are there any duplex or speed settings?
Sep 23, 2013 | Cisco - Linksys Wireless-n Home Router -...
Factory restore
According to Linksys support, you should not reset your WRT120n wireless router unless you are having difficulties with the unit. The WRT120n user guide also recommends applying other troubleshooting options before attempting to reset the device. Resetting the WRT120n restores the router back to factory defaults. After resetting the Linksys 120n, you''ll have to reconfigure the router back to your preferred settings.
Locate the Reset button on the back panel of the WRT120n. The button is labeled "Reset" and situated between the power port and the "1" Ethernet port. Press and hold down the "Reset" button for five seconds. The device resets. Open a Web browser on your computer. Type "192.168.1.1" into the browser's address field, then press "Enter" on your keyboard. A login prompt opens. Enter "admin" as the password. Leave the User Name field blank, then click "OK" to log in to your router and access your network settings.
Apr 02, 2013 | Linksys WRT120N Router
Need to reset router to factory settings
Google-search for "reset factory settings WRT120N".
Follow the instructions.
Aug 08, 2012 | Linksys WRT120N Wireless-N Home Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Where can i download a free installer for linksys wifi router with model # wrt120n
Are you trying to install WRT120N router?
You can do it manually without CD.
Connect the computer to the router. open the setup page and change the settings manually.
See how to setup Linksys WRT120N router
Oct 13, 2011 | Linksys WRT120N Router
I just bought linksys wireless router wrt120n but my labtop doesnt have cd driver hoe can i do the set up wizard with a cd?
Thank you for using FixYa
http://homesupport.cisco.com/en-us/wireless/lbc/WRT120N
you can download the installation application following the given link
Jul 20, 2011 | Linksys WRT120N Router
How can i create a password for my WRT120n router?
you will need to get into your router main settings via 192.168.1.1 in your browser the defualt password admin with no user name . or vs versa cant remember once there you can change it under account settings.
Mar 14, 2011 | Linksys WRT120N Router
How do i bring my wrt120n linksys router back to blank factory settings?
according to the user's guide I found HERE:
http://www.linksysbycisco.com/APAC/en/products/WRT120N
you can either use the red reset button between the ethernet ports and the power jack, or restore the
defaults from the Administration > Factory Defaults screen of the Router's browser-based utility.
Dec 24, 2010 | Linksys WRT120N Wireless Router
NetGear WGR614 Wireless Router Logo
62 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
