Question about RCA D52130 52" Rear Projection Television
Loss of picture
My set makes a sharp snaping sound from inside and the picture goes black for about 5 seconds and them comes back on. It will sometimes do this every 30 second and at other times it may be every half hour or hour apart. It did this about a year ago and the seller came and installed a small black chip that corrected this, but they are not in business any longer. At that time they said this was a fairly common problem and they indicated they had to install some form of new board to cure it permanetly, but they didn't and now they are gone. If anyone has a similar problem and fixed it please advise what you did. Thanking you in advance GSimms
  • greg simms Jul 08, 2007
    Since I posted this problem, I have fixed it myself. Out of frustration, I unpluged it, removed the back panel and blew all the dust out of it using an air compressor for higher pressure.
    (tv was used when I got it) So far I have not
    had a recurrance in 6 months. It seems that the
    accumulated dust was causing an arcing somewhere.
    It may not solve the problem for everyone but it
    worked for me.
  • greg simms Aug 31, 2010
    Shortly after I posted this, I decided to investigate the problem, so I unpluged the unit, removed the back and found there was a fair bit of dust inside. I got a dry air supply and blew all the dust off of
    the electrical components, avoiding contacting anything with the air nozzle. There was quite a bit
    of dust inside that you couldn't readily see. After putting the back panel on, I plugged it back in and
    its been running flawlessly since, thats almost 4 years now. It seems the noise was an electrical arc
    jumping across a dusty circuit.
One of the high voltage anode connections is arcing, usually as a result of sealer (rtv) having been incorrectly applied during manufactor. this may be repaired by a tv tech with application of rtv, or the crt may need replacing. DO NOT TAKE THIS TV APPART!! THE HIGH VOLTAGE ARC COULD BE VERY DANGEROUS.
Posted on Jul 01, 2007
When I turn on my Sharp TV the picture comes on for a second then goes black. The sound is working but the picture stays black.
hi quick test, in a dark room shine a flashlight on the screen, if you a can see an image, bring the menu up if you can see it the led or leds in panel may blown, thanks
shaun
Feb 15, 2017 | Televison & Video
Loss of picture HDTV
I believe he is right about those models being basically the same. They often make small changes like the layout of connectors so that they can have different models to sell to each store. It defeats the "price matching" ads some stores use. It sounds like one of two issues. Either a bad capacitor (a very common problem on this model, apparently) or a heat issue. Since it seems to happen every time, even if the machine has been offline for a while, and it takes so little time to do, I'm inclined to throw out the heat issue. Open up the back and see if you see any capacitors leaking, or crooked. I can't find images for capacitors in your machine, but I did find a site about bad capacitors on PC system boards - the capacitors are basically the same thing, so it might help you identify that. http://www.badcaps.net/pages.php?vid=5 If you do see bad capacitors, either solder on new ones, or just replace the entire board. It should be simple to replace. I can't find parts for this online, but you should be able to get them either from Sharp or from a local repair shop.
Aug 30, 2007 | Sharp Aquos LC-32D40U Television
Vw42L tv comes on withpicture for 5-10 seconds and screen goes black ,sound is still on
Most likely you either have a defective backlight inverter, bad back lamp. Based off of your model #, I'm gonna lean towards a back lamp.
May 10, 2012 | Vizio Televison & Video
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
My TV goes black with no picture but it has sound.
Sounds like the unit maybe running hot . Try reversing your vacuum so that it blows rather than **** and blown the unit out.
Oct 08, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Sharp Aquos LC-32D41U pictures problem
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Mar 29, 2009 | Sharp LC-32D41U 32 in. LCD Television
Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Dec 10, 2008 | Sharp LC-37D4U 37 in. LCD Television
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
RCA D52130 52" Rear Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
