Question about Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer
Lexmark Pro 205 Green Light, but says "Offline"
My new printer is hooked up to my wireless, installed and ready to go, but when I try to print to it, it says "offline" although the printer says it is connected.
  • Official Brand Answer
  • 3,344 Answers
  • 62 Answers
SOURCE: offline
Did you try right clicking the Printer icon in Windows and select Use Printer Online?
Posted on Oct 05, 2007
SOURCE: i installed my lexmark printer to windows vista, why does it say printer offline
PS. After running the Cleanup.exe you will need to reinstall the vista drivers as advised by 'mediateare'
Have fun
Posted on Mar 02, 2008
Ajkill
  • 2035 Answers
SOURCE: Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
1. Right click on My Computer and select Properties.
2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
5. Click the Details tab.
6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
If you are using an USB connection, they need to be at least USB 1.0 compliant.
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
1. Click Start, Run.
2. Type MSCONFIG on the Open line, then click OK.
3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
Posted on Mar 15, 2008
yooperbud
  • 8637 Answers
SOURCE: i have a lexmark x75;system is offline and cant get it ready
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 3278 Answers
SOURCE: suddenly wont print computer says its 'Offline.."
Researching your problem ...
Posted on Jan 21, 2011
LEXMARK PROSPECT PRO 205. HAS A CURRENT SOLUTION FINALLY BEEN FOUND FOR "PRINTER CANNOT COMMUNICATE WITH COMPUTER". LEXMARK CANNOT OR WILL NOT FIX THIS PROBLEM.
Chuck, I certainly sympathize with "tech support" that isn't, and with you on printers that don't get new drivers when new versions of Windows com out.
I'd be happy to enter a dialog with you to try to help you.
Have you tried another computer, hopefully running something different?
What connection are you trying to use? Does the printer have any alternative connection available? (say, USB or network)
When you first plug it into the computer, does the computer sense it's there and look for drivers, or does it ignore you?
Jun 16, 2015 | Lexmark Pro 205 Inkjet Multifunction...
Pro 901 won't print wirelessly anymore with macbook pro OS 10.9
switch off the printer and wait for about 10 or 20 seconds then switch it back on then wen it has reinitialised its self go to your computer and go to control panel and devices and printers and on the toolbar that sais add a device then there is a dropdown menu called add printer then follow the instructions.
Jan 28, 2014 | Lexmark Pro901 All-In-One Inkjet Printer
How can I get my IPad 2 to print on a Lexmark Prospect Pro 205, without keeping my laptop wired to the printer? I do not have a desktop.
Your printer and the devices trying to print from it should be connected to the same network. If it is, download our LexPrint app to your iPad http://bit.ly/IMbDlq. Since the Lexmark Pro205 is not AirPrint compatible, you would need the LexPrint Listener installed to a host computer.
Our latest Inkjet printers are already compatible with AirPrint.
Aug 17, 2012 | Lexmark Prospect Pro205 Wireless...
Computer does not recognize lexmark pro 205
Try to download an updated driver online: http://bit.ly/sW3OnE
Also, if your trying to print wirelessly, check if the WiFi light on the printer is green. If not, reconnect the printer to your network using the installer.
Jul 30, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Lexmark pro 205 spilling blue ink on documents
A firmware update for your model addresses the print quality problem you are currently experiencing. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update.
Should the error continue, then it could be a faulty printhead issue. Please contact Lexmark Technical Support Center to have your printhead replaced.
Apr 04, 2012 | Lexmark Prospect Pro205 Wireless...
Lemark pro 205
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Mar 24, 2012 | Lexmark Prospect Pro205 Wireless...
Lexmark pro 205 printing a blank page before a document
If you're using Windows, try to follow these steps to fix the problem.
  1. Start menu > Printers & Faxes > Lexmark Pro200 Series Properties window pops up > go to Advanced tab > Printing Defaults.
  2. The Lexmark Pro200 Series Printing Preferences window pops up > go to Advanced tab > More Options > under Suppress Blank Pages, enable "Enable blank page suppression"
  3. Save the setting.
  4. Try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark Prospect Pro205 Wireless...
I have a lexmark pro 205 all in one printer. It prints fine but I can't seem to scan a document and put in word. How do I do it and where can I get a manual for this product?
You will need to install the Lexmark OCR scan software to scan documents and edit it. Re-insert the installation disk in your computer to install the Lexmark OCR scan software. If you continue to experience scanning problem or you lost the disk, contact Lexmark technical support. Thank you for choosing Lexmark.
Oct 10, 2010 | Lexmark Prospect Pro205 Wireless...
Print server thinks printer is offline
This printer works only with selected printer and they do not work with other print sever to know the print server which they work please click on this link and then click
Hide/Show Additional Results
http://search.lexmark.com/printer/US/en/22N5000
This server will cost $149 instead you can buy wireless Lexmark printer X6570 at the same price,
Good luck..................
Jun 21, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
351 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
