SOURCE: Kodak easy share cx6200 problem
Amanda, I have a Vivitar Vivicam and I too had the same problem with my camera and PC. What you need to do is go into your controll pannel and "find" your camera. If it does not show, do an Add and remove hardware. You may have to reinstail the camera. I had to a couple of times with mine. It is a pain, I know, but that is part of having to keep up with todays technology. I hope this helps you.
SOURCE: Broken LCD Display
OMG the SAME thing happened to mine..excpets i have NO clue how mine happened.and it functions just as yours does..and im in the same situation money wise.
SOURCE: Kodak Easyshare CX7430 losses memory when shut off
I had this same problem. I couldn't get my camera to take anymore pictures while using my SD cards. So alls I did was took my cards to walmart, put all my pictures on a cd and then inserted my card again, when it brought up formating I okayed it to delete all the pictures since I already got them put on a disc. Once I did this is worked fine. Your cards can only hold so much depending on the size of your card and if you have to much on it your camera will not read it. Hope this helps you.
SOURCE: won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
SOURCE: Broken lcd on camera model kodak z1285
Have you thought about buying a "junk" one just to have parts for? Maybe place an add in the paper for one with a busted zoom lense for the screen? Or maybe search for a company that deals in "salvage", kind of like a junk yard for camera's.
