Panasonic sa-pt760 changer error - Audio Players & Recorders
5 Suggested Answers
SOURCE: I have the panasonic SA-PT960.W1 keeps flashing
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Posted on Jan 03, 2010
SOURCE: chgr error on my panasonic
Lock123 already solved my problem great service no wait time your site is the best one out
Posted on Jan 25, 2010
moorah1
  • 181 Answers
SOURCE: I am getting a F6 error when i try to turn on my Panasonic SA-PT760 home theater system?
Hello!
the problem with this error is faulty DC regulator I.C. chip, next to power module I.C. It's a hybrid chip and fatigue causes pins to break off chip's base. Anyway, it's a replacement part, you must have technician skills to replace it, plus some electronics tools. I don't remember the part#, but you'll find it at "panasonic.com/parts". Enter your model# and you'll see the list of all parts. It might be "STK" or "STR" at the beginning of part#. Better to open the unit and look up yourself. It's size about 2 by 1 inch, landscape oriented, with 10-15 pins connecting to the board. Don't try to just re-solder that chip. It's not a chip to board, but chip to pins failed connections. I've tried to re-do those pins, but without any luck. Chip might already died. good luck with your project.
Thanks,
Alex.
Posted on Jan 18, 2012
  • 1054 Answers
SOURCE: panasonic Home T, sa-pt760, message LOCKED
While the unit is on, press and hold the play button and the power button, display should say unlocked. If this doesn't work, try it using the stop button and power button.
Posted on Apr 03, 2013
I had to replug things in for my dish and unit sat sidewards to get to plugs. It now says locked and can eject disc, select source. Help
Try this:
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
Dec 31, 2015 | Panasonic...
How to connect a blue ray player with the sc pt760 sound system with dvd?
According to the models you provided it looks like the DVD player has only HDMI out and the sound system you have does not directly support that. I would suggest purchasing a HDMI audio extractor so that you can covert the digital signal from your blu-ray to an analog signal. However, there are other ways of doing this. If you provide me with your TV that you use I might be able to advise another work around.
Go on google and look for "hdmi audio converter" or "hdmi audio Extractor".
Make sure to look at review to determine the quality of the product and decide what device fits your budget.
Nov 23, 2015 | Panasonic...
I can't turn on the product
Always splash plenty of details in your question if you want good answers... I do not have a single clue what it is you want or need or even what item you are struggling with! Details are your friend. Good luck.
Apr 01, 2015 | Panasonic...
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
New zealand
www.panasonic.com/uk/support.html
Jun 29, 2014 | Panasonic DVD Home Theater Sound System...
Panasonic Home T, sa-pt760, message LOCKED
Apr 03, 2013 | Panasonic Audio Players & Recorders
I have a panasonic sa-pt760 receiver. I get a chgr error when I power it up and the disk changer makes a grinding sound. Nothing else will work. I totally removed the disk changer and still get the same...
When this unit powers up, it goes through a "startup sequence" that results in the mechanism being in a known state. The error message indicates that this sequence did not complete correctly. The typical "fix" for this is a mechanism rebuild. It is common for a gear or two to get out of time with each other and cause this message. The rebuild process is not a simple one and should not be attempted without the service manual and some experience. It is rare for parts to be required for this fix.
Please seek professional assistance for this repair.
Dan
Mar 03, 2011 | Audio Players & Recorders
Sa-pt760 get chnger error, disc tray does come out and just makes noise. I have tried unplugging, also hold power button and number 10 on remote.
There is a mechanical problem with the changer. This is a relatively common failure that requires a "rebuild" and may also require a gear or two. The typical parts cost for this repair is under $20 and if I remember correctly, there is also an engineering change/modification that should be applied to this as well to prevent this from ocurring again. Since the rebuild requires a specific build order and alignment, this is NOT a DYI repair (unfortunately). Your best bet is to locate an authorized Panasonic service center for this repair.
Dan
Mar 21, 2010 | Audio Players & Recorders
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
442 people viewed this question
 Grubhead
Grubhead
