Question about Electrolux Refrigerators
Caravan fridge wont ignite when on gas - Electrolux Refrigerators
  • bazsheppard Feb 19, 2012
    hi, the fridge is getting gas to it , there's just no spark, i took vent off outside caravan & lit it with a gas lighter & it worked fine, turned it off & tried again still no spark.
Does fridge work on 12 volt? If yes, 1 check and make sure you have 'good' gas. Next you can check the orvice/ignition area for any forgien matter, cobb web/spider webs must be removed. You can blow out that area with nan air hose. wear safety glasses!!! follow instruction for lighting. If you still do not have any flame you mave have a bad pilot valve.
Posted on Feb 18, 2012
3 Suggested Answers
  • 256 Answers
SOURCE: N90 EHLtype C 11 Pilot gas wont stay alight.
Your problem is probably with the thermacouple. Contact a service company.
Posted on Apr 13, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: Large fridge & freezer in
IN THE PAST I HAVE TAKEN THE UNIT OUT AND TURNED IT UPSIDE DOWN, AND LEFT IT SIT FOR ABOUT 1 MONTH. THEN REINSTALL THE FRIDGE, AND IT WORKS AGAIN.. .. REASON YOU MAY ASK ? THERE IS A LITTLE BULB THAT THE FLAME KISSES, AND IT SEEMS IT GETS TRASH INSIDE THE BULB, AND SLOWS THE HEAT TRANSFER .. YA I KNOW IT SOUNDS CRAZY, THAT'S WHAT I THOUGHT ALSO.. OH AND TO OPERATE THE UNIT NEEDS TO BE LEVEL (CHECK THIS FIRST !!) ..LAST ONE I DID WAS ABOUT 25 YEARS AGO..
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Posted on Jul 20, 2011
Gas igniter on N604 3F fridge does not ignite gas, how do I fix this. Thanks
when starting on Lp does board click or light on board lite up see if voltage to ignitor if no voltage bad board if voltage to ignitor bad ignitor if lites check burn tube
Jun 30, 2014 | Thetford Refrigerators
Caravan fridge
See if you have access to a schematic on the unit itself. The fact that it works fine on gas tells you there is nothing wrong with the ammonia solution in the tubing. For that unit to work, the electric heating element has to boil off the ammonia and this is not happening. Check on the schematic if there is some kind of fuse or additional in line switch which is preventing the heating element from turning on and doings its job.
Nov 27, 2013 | Refrigerators
I NEED A USER MANUAL FOR ELECTROLUX GAS FRIDGE IN MOTOR HOME. MODEL IS RM 2260 AND PRODUCT NO. IS 9215430-01. GAS IGNITION SYSTEM NOT WORKING - THANKS FOR ANY HELP JAMES GREIG SMITH
Hello, here is the manual: -
http://web.me.com/danperkinsartwork/Autohomes-Bedouin/Manuals_files/Electrolux%20RM2260%20operating%20and%20instalation%20instructions.pdf
Also found this site with a list of parts for the fridge you mentioned
http://www.leisureshopdirect.com/Caravan/ventilation/Dometic_Caravan_Fridge_Spares/Dometic_RM2260_Fridge_Spare_Parts.aspx
Hope this helps, good luck
Aug 04, 2011 | Electrolux Refrigerators
Large fridge & freezer in caravan. Works fine on mains electric but fails to cool on gas. The pilot ignites and fridge cools very slightly on gas
Jul 20, 2011 | Dometic Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Hi ,I have a Leisureline caravan with a Dometric 3 way fridge/freezer, goes well on 12volt and 240 but I can't get it to work on gas , plenty in supply , light flickers with button pushed in. We got no...
Ian - are you pushing the igniter button rapidly while holding the gas supply button in? This works for us. If you have any fluid in the gas line it will not light; you would need to get this checked out. Access is through the bottom outside vent. Good luck.
Sue
Aug 29, 2010 | Dometic RM2193 Compact Refrigerator With...
Electrolux fridge in my caravan will run on gas,
Hi it sounds time to pull it out and give the ignition box a good blow out to remove dust and cobwebs. Also remove the jet in the supply pipe where it screws on to burner box. Just wash and clean it dont poke anything in the jet hole. Graham
May 13, 2010 | Refrigerators
Apr 13, 2010 | Thetford Refrigerators
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Aug 27, 2008 | Electrolux Refrigerators
Refrigerators Logo
535 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
