Question about Schwinn Original Airdyne
My schwinn airdyne display unit battery holder is lost. How can I fix?
MNfisherman
  • 11896 Answers
SOURCE: schwinn 920i hrc exercise bike
6 Volt 2.5 amp
http://www.sportsmith.net/ItemForm.aspx?item=P01001700030685
Posted on Sep 22, 2010
terpcafe
  • 16 Answers
SOURCE: Battery cover & battery type for ergometer older unit
The battery cover is no longer made since this bike was last built in the late 1980's. I would recommend giving the man a timer/watch. I do have one of these little black round batter covers, and would sell for $25. However, all it does is create a timer for the rider. He already can use the analog computer to see his mileage, load, and can re-set the lower mileage to zero every workout. All the battery cover will allow is for him to set a timer for how many minutes he wants to workout for. Or he can pust the start button to time his workout. (my email is terpcafe@yahoo.com)
Posted on Sep 27, 2010
terpcafe
  • 16 Answers
SOURCE: How to attach book rack to 1984 Schwinn Airdyne
Remove the computer support brackets by unscrewing the bolts holding it to the bike frame. Get 3-4 inch long bolts (to replace the computer support bracket bolts) and nuts that will tighten on the other end and place the book rack support brackets in front of the large inverted U part of the bike frame. Align the holes of the book rack support with the computer support leg holes. Insert and tighten the new longer bolts with the computer legs on one side of the U and the book support legs on the other side of the U. Once you tightne the nuts, your airdyne now has both the computer and book rack on it.
Posted on Jun 06, 2011
terpcafe
  • 16 Answers
SOURCE: I need to tighten the chian on my schwinn airdyne.
Two places to tighten the chain and it requires you to loosen the nuts on BOTH sides of the bike, almost at the same time. Start at the fan wheel (top) of the bike. First thing you need to do is to loosen the little nut at the hub of the fan wheel on both sides. Unscrew it almost to the point of taking it off, but leave it screwed on the end of the bolt so it will stay on the bike. Then use an adjustable wrench to loosen the nut a bit on one side and then do the same on the other side OR use both hands and loosen both at the same time by unscrewing with adjustable wrench in opposite directions on both sides. Once the wheel is loose, you want to sit in front of the bike and pull both of the large nuts at the same time toward you and the chain will tighten. The goal is to have the fan wheel centered and for you to be able to see about 1/4" inch of clear gap behind the nut on both sides. Then use your fingers to tighten the nuts to the frame just enough until you can use the adjustable wrench again. I have sometimes used a flat head screwdriver to insert into the gaps to prevent the chain from loosening up. The tighten the nut on both sides of the bike. Be sure you tighten the little nuts as well (they are called chain tensioners). That SHOULD do the trick. However, if your bike chain is still too loose, you need to do the same for the chain at the pedal area, That requires the same thing all over again, but in most cases, the chain loosens at the top part of the bike (fan wheel place). However, if you do work on the pedal area, you want the chain to be pushed toward the fan and not toward the **** side of the bike. It may sound crazy but that's the only way to tighten the chain. give me a thumbs up with my solution.
Ironfist109
  • 3018 Answers
SOURCE: I am looking for a schwinn airdyne manuel.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 29, 2011
What kind of batteries does the schwinn Airdyne take its about 22 yrs old?
Most computer console batteries for Airdynes are AA, you'll have to open up the console/meter housing in the back to replace them. I will be attaching a link to a diagram of the housing. Hope this helps, sincerely SportSmith..
http://www.sportsmith.net/images/product_support/schwinn/service_manuals/Airdyne%20Evolution%20electronic%20trouble%20shooting.pdf
May 21, 2015 | Schwinn Cycling
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
User Guide/Manual for Schwinn Airdyne AD3
Schwinn Fitness has many of their manuals here: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . The direct link to the owner's manual for all Airdyne exercise bikes is available here: http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_Airdyne_Evolution_OM_web.pdf . If you need the assembly directions, see the Airdyne AD4 guide: http://download.nautilus.com/supportdocs/AM/Schwinn/SCH.Airdyne.AD4.AM.EN.pdf . The AD3 and AD4 are very similar.
I hope this helps.
Apr 08, 2015 | Schwinn Cycling
My computer on my Schwinn Airdyne's numbers are only half showing. Is it low ink
the displays use LCD in the display not ink it sounds like the battery(s) are low see about replacing them and the display should return to normal if the batteries are new the display might be damaged due to age, heat, or physical contact with the display i.e. pressing the display, hitting it, something fell on it
Jun 04, 2014 | Schwinn Original Airdyne
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
I Need Console for 1988 Airdyne
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988.
One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00
Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website.
Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years.
Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.
Good Luck.
Jan 06, 2013 | Schwinn Airdyne Ad4 Upright Bike
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
Lost the small (black) battery cap that holds the button (357) battery in place. It's an older AIRDYNE. Located just below the odometer or timer. Presently holding with Gorilla tape.
That part is no longer made, stopped making them in 1990. You will simply need to use a watch to time your workouts. That's all it does anyway.
Feb 05, 2011 | Schwinn Original Airdyne
Jun 19, 2010 | Schwinn Original Airdyne
Owner's manual for older Schwinn Airdyne
http://support.nautilus.com/support/schwinn/uprightbikes/prdcdovr~3550012/Schwinn+Airdyne+Exercise+Bike.jsp
Follow this link and you can download the owners manual as well as the exploded parts schematics. There will be information about the different years. other than the consoles they have remained the same for 20 + years. If you ever need to replace the bottom bearing be sure to get the lock ring as well. It changed from left hand thread to right. Thats it. You can also upgrade the console to the newer version. A little expensive but with proper care a 20 year old Airdyne will last till the frame rusts out from under it.
Apr 23, 2009 | Schwinn 430 Elliptical Trainer
Schwinn Original  Airdyne Logo
249 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
