We have a Hitachi C28W1TN, which is just under 10 years old that has recently started switching itself off. It goes onto standby by itself and when we switch it back on, it instantly does it again. At first, it started happening when we had been watching the tv for a couple of hours or so. We would switch off the main power for a few seconds and then switch it back on and it would be fine again for a few more hours. But over the last couple of weeks it has got progressively worse and now it happens after it has only ben on for 15 minutes or so and even when we switch off the main power, it happens again 5 minutes later. We have tried covering up the sensor for the remote incase it is picking up some signal from elsewhere but that makes no difference. Any ideas as what may be the cause would be greatly appreciated. Is worth taking it to be repaired? Thanks.
It's been a while since this post, but I may have had a similar problem with my Hitachi. With no reason it would switching on and off randomly. The problem was with a solder joint on main relay - it was cracked and would not keep the coil powered so i kept flickering on/off. This relay is located on the front of pcb, between high voltage area and the switch and on my tv it is blue. Check all four joints and apply some new solder onto them. Make sure the tv is not connected to mains ;-) Hope this helps
Posted on Aug 07, 2010
Elonex tv keeps going on standby, take 10-15 times for it to work
It sounds that there is some short circuit with its SCL-SDA rail, at its main digital circuit board. It will be best to contact any service technician, as troubleshooting the main board is a skilled work.
Nov 25, 2013 | Televison & Video
Elonex tv keeps going onto standby, take about 10-15 goes to work.
Sounds like you may have some capacitors going bad. If it is a high end TV it may pay you to take it to a repair shop.
Nov 25, 2013 | Computers & Internet
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
I have a Hitachi TV and it has recently started switching itself off for about 5 minutes before it comes back on again. It is only a year old. Could it be overheating?
Yes the overload sensor is cutting in You have some componenent/s getting hot. You need to do a warranty repair callout before more components burn out completely.
Please rate the help to keep the FREE service online ++++ Thanks for using FIXYA
Sep 03, 2009 | Hitachi 43FDX01B TV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Oct 05, 2007 | Televison & Video
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
