Question about HP dc Computers & Internet
Motherboard 365865-001 pinouts
Swapping my hp dc7100 to a new tower and i'm not going to be able to use the front panel connectors or the power switch/led from the hp tower. and the pins are not labeled on the m/b. i need to find a diagram that labels each pin. just like what you would get if you bought a motherboard. on this motherboard it does say "pb" and "led" but, the "pb" is in the middle of 4 pins and "led" covers 4 pins. my tower has just a 2 pin connector.the new tower is an Antec 900.
  • gstine
    gstine Feb 18, 2012
    old tower is a hp cmt dc7100
3 Suggested Answers
mukexh
  • 20 Answers
SOURCE: need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
Posted on May 13, 2009
SOURCE: connecting front panel leads of generic case to 4600 motherboard
The 10 pin (one pin missing as a key pin) front panel connector on the Dell 4600 had the following pin out:
this end pin
function is
unknown
BUT must
be gnded
to center
pin
l
l
l ground
l ______ l
l l
l RESET
l l l HD LED
l l l l l +
o o o o o
x o o o o
l l l l +
Power l l
Switch l l
Power
LED
Posted on Sep 20, 2009
Dell T7400 Front Panel Pinout
The wires should be labeled such as HDD LED, POW LED
On the motherboard you should see corresponding with + and - Colored wires are always the + and black (ground) is the -.
Dec 21, 2012 | Computers & Internet
I need pinouts for the sony vaio pcv-1116's motherboard
This is Not a Solution. Using Solution box as a Clarification/ Comment box.
What other model numbers are there listed? I should be able to cross-reference a PCV-1116, but cannot. Once I find the motherboard, I may be able to tell you what the pinouts are.
(Such as Front Panel header pinout on the motherboard)
Post back in a Comment.
Regards,
joecoolvette
Dec 12, 2012 | Computers & Internet
Replace motherboard
Rob, Rob, Rob.............if I told you a thousand times, I............
Oh.......... where was I?
1) Power cables from Power Supply to motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237538&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3878557
A) 24-pin ATX main power cable;
Looking at the motherboard view the Right side. To the right of the Blue 39-pin IDE connector, is the 24-pin ATX main power cable connector, on the motherboard.
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The power cable connector has a Lock on one side, and the motherboard connector has a matching Lock Tab.
When the power cable is deemed to be installed Correctly, and Properly; the Lock's hooked end is over the Lock Tab.
[Note* Color of connectors does NOT matter ]
B) 4-pin ATX +12 Volt power cable;
The processor socket is white in color. Around it is the black mounting ring.
The 4-pin ATX +12 Volt power cable connector on the motherboard, is to the Left/Bottom corner, of that black mounting ring.
Square, whitish (Opaque), and 4 socket holes.
This is a general example of a 4-pin ATX +12 Volt power cable; and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) Peripheral power cables from Power Supply;
A) The Harddrive is a SATA unit. Uses a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
B) The optical drive/s (CD/DVD drive) are also SATA units. They use a SATA power cable.
A SATA power cable's connector has 15 contact pins. Between it, and the SATA data cable, it has the longer connector.
Peripheral Data Cables;
This is a general example of a SATA data cable, it's connector, and a SATA connector on the motherboard,
(Note* Color does NOT matter),
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Here you can see the L-shaped opening of the connector, and matching L-shaped tab on the motherboard connector.
Most SATA power cable connectors, and SATA data cable connectors, have a lock. All you see is a 'bulb' type affair on top of the connector, that you squeeze down with a thumb tip.
Depress to remove, depress to install.
A 90 degree elbow connector for the SATA data cable, is used on the Harddrive, and optical drive. The straight connector end of the cable, plugs into the motherboard.
There are two SATA connectors on the motherboard. One White, one Black. One of them should have a SATA1 next to it.
(Or one will at least have SATA2 next to it)
SATA 1 connector is for the Harddrive. SATA 2 connector is for the optical drive.
The beauty of SATA is though, you can connect any SATA device, to any SATA connector on the motherboard; and BIOS will find it.
So it really doesn't matter what you plugged in where, as far as those two SATA headers are concerned.
3) Processor Fan cable, System Fan cable (Computer case fan);
Going back to the HP Support page above, and Motherboard Specifications; scroll down the list.
Click on the + sign to the left of the blue - Motherboard layout
Below the ATX12V1 connector is the System Fan connector.
(SYS_FAN)
This is where the computer case fan connects.
(ATX12V1 connector, is the 4-pin ATX +12 Volt power cable, connector)
Above the Ram Memory slots, and a little to the right; is the Processor Fan connector. Power to the fan. (CPU_FAN)
4) Front Panel audio connector, optical drive audio connector, Front Panel USB connectors;
Bottom edge of motherboard, from Left to Right;
Yellow connector is AUDIO1. Front Panel audio.
White connector is ATX_IN
For the audio cable from the optical drive.
Black connector (HD_AUDIO) is also for the Front Panel audio.
Don't know how they have the Front Panel audio, hooked up.
YOU will. The cable connectors to them are different from each other.
Further to the right are two white connectors. EACH one can support TWO USB ports.
One should be for the two USB ports in the Front Panel.
The other will go to a Card Reader in the Front Panel.
All the way to the right corner is the Front Panel header.
This is where the main wires from the Front Panel go.
Power On switch, Power On LED (light), and Harddrive activity LED (light)
The cable, and connector should match that 9-pin header.
If not here is an HP 9-pin Front Panel header - pinout,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the photo, and pinout. (Dave G)
Believe that is it.
For additional questions, or to have me clarify anything I have stated above, please post in a Comment.
Regards,
joecoolvette
(Ya know I was jus kiddin' above, right?..............
Rob?...................................................................Rob?)
Nov 27, 2012 | Compaq Presario SR5712F (SR5712F-B) 19 in....
Need a schematic to wire front panel on n1996 ms 7061 motherboard.
1) http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07557&lc=en
2) http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the photo, and pinout, of a 9-pin HP Front Panel header
(No.9 pin. Reserved. It is/was, reserved for the factory.
5 Volt DC test point. It is N/C. Not Connected)
Nov 26, 2012 | MSI : MS-7061-020...
I am looking forthewireing for a hp pavilion xt919
A) Power cables from Power Supply to motherboard:
1) Product information > Product specifications > HP Pavilion XT919 Desktop PC Product Specifications and What Ships in the Box,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06613&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=58461
2) According to my sources the motherboard is an Asus CUW-AM,
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=46171&prodTypeId=12454&prodSeriesId=46171&objectID=bph07170
If this indeed holds to be true, scroll the page down, look at the illustration under the Figure 1: Motherboard layout, heading.
Look at number 22 on the right; ATXPWR
Now scroll down to the motherboard photo.
The white connector with two columns of 10 socket holes, to the right of the black Ram memory slots, is ATXPWR.
Proper name is 20-pin ATX main power cable connector, on the motherboard. This is an example of a 20-pin ATX main power cable, and it's respective motherboard connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note in the three photos the Lock on the side of the power cable connector, and the Tab on the side of the motherboard connector.
The Lock operates like a see-saw on a playground.
To remove the power cable the top is squeezed in, and this causes the hooked end of the Lock to come away from the Tab.
When the 20-pin ATX main power cable is deemed to be properly installed tightly to the motherboard, the hooked end of the Lock will be over the Tab.
B) IDE (PATA) harddrive uses a 4-pin standard Peripheral power cable.
So does the Optical Drive/s,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the rounded corners when plugging it in.
{Power cable has been misnomered as a 'Molex' power cable. Molex came up with the connector design. The name stuck. Kind of like calling an adjustable open-end wrench a Crescent wrench }
C) Floppy drives and card readers use a 4-pin small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
D) Number 6 -> SYS_FAN, is where the Processor fan plugs in.
SYS_FAN stands for System Fan. A computer case fan. The illustration is wrong.
E) Number 21 is PS_FAN.
That to me stands for Power Supply Fan. Another misnomer. The Power Supply has it's own fan, and doesn't need power from the motherboard for it.
I'll bet this is where a System Fan, or computer case fan, would connect.
F) Number 29 points to the Primary IDE connector on the motherboard.
This is where the 40-pin IDE flat ribbon cable, plugs in for the Harddrive.
Number 24, Secondary IDE, is where the Optical Drive's, IDE flat ribbon cable plugs in.
Note*
The rectangular connectors for the IDE flat ribbon cables, has a 'bump', or protrusion, on the outside edge towards the middle,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
In this photo it is at the top/middle. There are different styles. Square block, or the two piece design shown.
These bumps, or protrusions line up with a cutout.
A cutout on the motherboard connector, or a cutout on the circuit boards for the harddrive, and optical drive.
IF there is no bump, or protrusion;
There is a faint red strip on one side of the IDE (PATA) flat ribbon cable.
The red strip denotes which side Number 1 wire is on. Number 1 wire in the cable, for number 1 pin in it's connector/s.
http://pinouts.ru/DiskCables/IDE_pinout.shtml
Here you can see by the pinout above, that for the black Primary IDE connector, and the blue Secondary IDE connector, Number 1 pin is at the Top.
Red stripe on edge of IDE cable will be at the top, when the cable is attached.
When plugging into a harddrive, or optical drive, Number 1 pin ALWAYS goes toward the power cable.
Towards the 4-pin standard Peripheral power cable.
Red stripe will be towards 4-pin standard Peripheral power cable.
H) Number 14 CD_IN is where the audio cable from the MAIN optical drive plugs into. If you have two optical drives only the main, or Primary optical drive audio cable plugs into the motherboard.
I) The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Under the photo of the motherboard, the pinout for the Front Panel header is shown, though not very legible.
In the illustration the Front Panel header is Number 30 - Panel.
Looking at the pinout, and looking at the actual Front Panel header on the motherboard photo, it looks as though they have the pinout upside down, in relation to how it actually is.
Note in the motherboard photo, the Front Panel header is shown with 5 pins across the Top, then a space, then 4 more pins.
The Bottom row is 10 pins in a row.
In the Front Panel header pinout, they show 10 pins going across the Top. 4 pins going across the bottom, a space, then 5 pins.
Upside down.
I think it should be this way,
Top Row starting on the Left side going towards the Right;
Pins 2, 4, 6, 8, 10, No Pin, 14, 16, 18, and 20.
Bottom Row starting on the Left side going towards the Right;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
1) Pins 2 and 4 are for a Reset switch, IF a Reset switch is used.
2) Pins 6, 8, and 10 are for the Power On LED. (Light)
This is for a computer that has 'Turbo'
Dual light Power On LED. May have Green and Yellow lights.
Green for 'Turbo', and Yellow for Normal.
Bunch of hooey, really.
'Turbo' mode is the computer operating in a normal mode, and Normal mode really is the computer slowed down.
Pin 10 is for the Negative ( - ) wire.
Pin 6 and Pin 8 are the Positive ( + ) wires. One for the Green side of the Power On LED, one for the Yellow side of the Power On LED.
3) No Pin 12
4) Pins 14, and 16 are for the HarDDrive activity LED. (Light)
Pin 14 for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
5) Pins 18 and 20 are for the Power On switch.
6) Pins 1, 3, 5 and 7 are for an internal speaker. Used to hear BIOS Beep Codes.
Pin 3 is for the Negative wire ( - ), and Pin 7 is for the Positive ( + ) wire.
7) Pins 9 and 11 N/C. Not Connected. (External SMI lead)
8) Pins 13 and 15 are for a Keylock switch.
Some computers have a Keylock. Unlocked the computer will come on.
I -> believe, Not connecting anything to these two pins, is like having the Keylock in the unlocked position.
May be wrong. May have to have a jumper wire across these two pins for the computer to work.
9) Pins 17 and 19 are for a Message LED
(Sleep/Standby)
HOWEVER, the best method IMHO is to use an LED light, and touch two pins at a time, to see which ones are for the Power On switch.
When the computer comes on, (Power Supply), then you know which pins are for the Power On switch.
Computer running, do not touch those two pins again, and check the rest of the pins.
Computer turns off, and starts again? Restart switch
LED light blinks? Harddrive activity LED
LED light stays on steady? Power On LED.
Finding which two pins are for the Power On switch, also helps tell you where the rest of the pins are, by looking at the pinout on the HP Support page.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph05159
Scroll down to Figure 4: Front panel connectors
Same Front Panel header used for this TriGem (Cognac) motherboard.
Clearer though.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 02, 2012 | HP Computers & Internet
I'm looking for the pinout for the FRONT PANEL
DX-5150 Illustrated Parts Map Refer to Page-2 for Complete Motherboard Connections and Description
Actual Image of the Motherboard (Rotate it 90 Degree Clock-wise for a better view)
(The above illustration is at Page-2 of the Manual)
Please download the Manual and the Motherboard photo from the above links and make the Front Pannel Connections.
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | HP Computers & Internet
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
I m trying to install a new motherboard and i need the manual or motherboard diagram for the pinout for the power connector
You need to specify the motherboard's make & model in order that I could provide you with further assistance.
Mar 24, 2010 | Computers & Internet
Power connections for tower led's
The manual in question can be located here
http://download.intel.com/support/motherboards/desktop/sb/d1047103_en.pdf
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
Computers & Internet Logo
421 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
