Question about Hatco Kitchen Appliances - Others
Need wiring diagram for hatco tk 100 toaster
Tk 100
4 Suggested Answers
  • 63 Answers
SOURCE: need wiring diagram for hatco fr-5 rethermalizer
hi my name is mark, that model is a burger king unit. you need to call them with the seral number to get diagram. check out hatcocorp.com
Posted on Mar 10, 2009
  • 63 Answers
SOURCE: need to verify wiring on hatco 3sc9 sink heater/rethermalizer
hi my name is mark, leave your e-mail address and i will send a pdf file
arwebs626
  • 11 Answers
SOURCE: wireing diagram for a TK Bedford Truck
try this guy he seems keen.
Posted on May 11, 2012
How to find schematic for a hatco tq 700 toaster
Ok great question but according to law companies do not have to offer schematics see the link below this is all the public information on your unit Hatco TQ 700 Parts Manuals
Feb 12, 2018 | Hatco Kitchen Appliances - Others
Model TQ-800H gets toohot and shuts off.
i've found this to be a common problem.... typically, people will clean out the crumb tray at the bottom of the toaster, whilst other crumb bits remain elsewhere inside the toaster, especially close to the heating elements, and alot of newer models today have a safety sensor. try giving it a good thorough cleaning and visual inspection to rule out a little excess building getting in your way...literally. lol. hope this helps
May 09, 2016 | Hatco Kitchen Appliances - Others
My toaster doesn't give enough heat to use it
follow this test with multimeter, and fix it. God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord.. If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Nov 08, 2013 | Hatco Conveyor / Toaster
Heat is low
please make this test with the multimeter.God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord If the oven doesn't work on its toaster and oven functions, test the main switch As needed, check the fuse .
If the toaster oven stays on when the door is opened, check the main switch (). If the oven doesn't heat, test the heating elements.
Can I put a higher watt heat tube in my TQ-10 converyer toaster
Your toaster is rated at 1800watts which is the power rating.
Your toaster is rated at 15amps which is the current rating.
Your toaster is rated at 120v which is the voltage rating.
Electrical Load,Power Rating and Current Drawn through the Main Supply is Calculated By: Power = Amps x Volts
1800=15x120=.........1800w.
Manufactures work out what size of cable and protectio to incorporate by using this design principle.
If you try to increase the bulb size it will alter everything and the internal wiring was not designed to take this extra load.
So, NO...
Oct 02, 2009 | Hatco Kitchen Appliances - Others
Need Hatco model tk100 service manual
I am sure there is one to download but did not found anything with google...
If search engines are no help, just ask some deep web specialists, e.g. http://manualfox.com - this is a manual search agency and if they don´t find it, it does not exist in the Internet.
Aug 31, 2009 | Hatco TK-100 16-Slice Toaster
Need wiring diagram for hatco fr-5 rethermalizer
Feb 21, 2009 | Kitchen Appliances - Others
Need to verify wiring on hatco 3sc9 sink heater/rethermalizer
Jan 29, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
118 people viewed this question
Top Hatco Kitchen Appliances - Others Experts
Craig Butler
Craig Butler
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Hatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
