I am not receiving no ice. I can receive water but its not making no ice.
Comment by Guest, posted on Jan 24, 2008
Water started shooting out of Ice maker onto the floor. I Dumped all ice and I used a blow dryer to melt cubes in maker. I also put in a new filter. I'm waiting to see if ice starts making. How do I know if it is working? Those plastic teeth moved down then stopped. Is that the norm. Does it have a sensor that knows when the ice is ready to be dispensed??
ice maker not getting water but i do have water at the door replace fliter but still no water filter was really dirty.check all lines coming in good water pressure but the water at door is weak and none to icemaker,i there another filter somewhere or screen
i was cleaing the compartment for the fruits/*veg tray behind it was a container for water it was frosted i clean that and notice that the ice maker had stop making ice what could be my problem? thanks DT Hawaii with no ice.
Check that temp. is 17 degrees or colder (better if colder) inside freezer. Could be the ice maker motor module is shot or the IM solenoid valve isn't working.
Comment by HVACRH20, posted on Jan 09, 2007
A poor rating huh? So what did you find was the problem then?
Was this solution helpful? Show your Appreciation by rating it:
I've got one, and the bracket in the back that connects the motor to the long screw-crank in the floor of the ice tray broke in half, so no ice was getting pushed to the door to come out the front. Putting in a new bracket started ice coming out again.
I had the same problem. The water fill hose was frozen. The fill hose is on the top right side of the icemaker coming down from the top of the freezer. Hit it with a hair dryer for a few minutes and work it back and forth until you see some drainage.
Water works and you can see one set of cubes ready to be dispensed but it quits working at that point. I have an external inline water filter as well as the one inside My Frigidaire Gallery.
