Question about Kenmore 73952 Gas Dryer
Kenmore 73942 Dryer will only run on AIR DRY.
It started making a clicking noise then stopped. Now it will not run except on the AIR DRY/FLUFF setting. If I hold the start button in on other settings it will run but not heat up.
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
  • 95 Answers
SOURCE: must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Posted on Dec 30, 2008
dragonsthatk
  • 547 Answers
SOURCE: Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Posted on Feb 20, 2009
  • 686 Answers
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
Dryer making clicking noise when running. Heat no longer working. Gets "stuck" in a cycle continues running and dial not moving.
Based on symptoms, this is a gas dryer. The clicking that you hear is the solenoid opening so that gas can flow and be lit. Except that gas isn't flowing, or the igniter is burned out (if or pilot is blown out if so equipped).
It is normal for the dial not to move unless it is in a timed dry mode (like air or freshen mode) because the moisture level of the clothes is not changing.
Jun 13, 2010 | Kenmore 63942 Dryer
Kenmore Elite 73942 Gas Dryer only runs with start button held
Unplug the dryer. Open the control console.Mark and remove the wires from the start switch.
Using a volt meter set for continuity,touch meter leads to R1 and R2 while pushing the switch. No reading is a bad switch.
Touch meter leads to R2 and CT1. No reading is a bad switch.
If the switch checks out good the start windings in the motor are bad.
Dec 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore electric dryer, won't start and clicks by time dry knob
usually the thermal fuse goes and dryer dies part number 3390719 located in front of dryer on top of the blower wheel housing,when you read anything out you have to pull one of the wires off to get correct reading.also on some of the dryers there is a switch on the pulley that will kill the dryer if the belt breaks
Nov 02, 2009 | Kenmore 62602 Electric Dryer
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
MY DRYER DOESN'T GET HOT
There are a few things to check out. 1. This may seem obvious, but make sure your temperature switch is not pointed to "fluff/air dry".
2.Is the motor running? It has to, to dry three. Make sure your door switch is engaging properly.
3. If you are so inclined, unplug the power cord and remove the back lower panel of the dryer.) Remove the vent pipe & allow the unit to run, if you now have the proper heat this means the vent is block, check the outside vent hood, the sometimes have a screen just inside that will block up not allowing for air flow.
Check all wire connections to make sure they are attached properly. If they are burned or worn, they need to be repaired or replaced. Any disruption of the circuit to the dryer element will stop its functioning.
4. Next, look for the thermostat.. which is usually a small circular metal device attached to the dryer element canister. Unscrew it and shake it slightly. You should hear a clicking noise. This should indicate that your thermostat is working (but not always!).
5. Remove the heater element canister cover and check to see that there is continuity of the element wires (no breaks). If there is a break, it needs to be repaired of replaced. You can take the heater element to a repair shop and be tested for current. If you think that you can repair any of this on your own, then go for it. Always think safety first before proceeding
Feb 21, 2009 | Kenmore Dryers
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
