Need instructions on changing belt pic.too for Amana Lw3502w 10YRS OLD
I need help on installing a belt on my Amana Washer LW3502W i need a diagram of how to get the new belt on. Can you help please?
Take off front of machine- 2 screws bottom sides. You need to take the bolts out of the motor brackets (4) and it would help if you drained all of the water out of the water pump so you can take the hoses off. Release the spring pressure on the idler pulley and unclip the motor plug on the side of the motor near the top. Now you should be able to pull the motor out and gain access to the three torx screws on the bottom of the pump. Make a note of how the pump sits on the bottom of the motor and how the belt is routed through the legs of the pump and around the pulleys. Reverse the procedure and reassemble. Don't forget to re-apply the spring pressure to the idler pulley. The motor drive pulley should be clean, shiny, and smooth. If not the belt won't slip like it should and will burn up when the washer spins. It has to slip untill all of the water is out of the tub before it spins up to full speed. Found this- and I'm gonna try it.
Posted on Jun 24, 2009
  • 903 Answers
To be honest it takes an engineer long enough to fit a belt, they use a speacial tool. i would personally let an engineer fit it. It you already have the belt then they will only charge you for the fitting.
Posted on Oct 26, 2008
Belt replacement
belt goes on the bottom of dryer. look up your model on internet on replacing belt . its pretty easy. if old belt is still on make a diagram of how belt goes on, also take a pic.
Jan 30, 2014 | Amana DLW330RA Top Load Washer
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
http://www.partselect.com/ModelFrames.aspx?ModelID=29693&ModelNum=ALW480DAW&mfgModelNum=PALW480DAW&ManufactureID=1&Selected=31971&Position=7&mfg=Maytag&Type=&Mark=7
http://www.applianceaid.com/amana-wash.html#belt
Oct 21, 2009 | Amana ALW480DA Top Load Washer
Diagram with replacement belt doesn't seem to match old manual
I haven't worked on a belt drive but here is the Sears parts site for your washer with diagrams of the console, drive system etc. You may get a better idea of how to replace the belt from these.
Here also is the Whirlpool / Amana installation and maintenance document for Amana belt drive washers. It may look similar to yours.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56310258b0952a4e8525729c0056d75b/$FILE/Amana_Searcy_TL_Washer.pdf
The other thing I'd check is Whirlpools list of documentation for their laundry products. Check some of the washers that they make for one that looks like yours and you should get a better idea.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1&Count=30&Expand=6#6
Oct 08, 2009 | Kenmore Washing Machines
My Amana washing machine stopped spinning.
moz-screenshot.pngac4805b.gifhere is the image on how to change the belt......it's pretty easy to do as you can see by the diagram.PS2027742 is the part number on the belt.
Oct 03, 2009 | Amana ALW480DA Top Load Washer
Replace Broken Belt
Here is the link that will explain how to do it:
check this link u ll get if u dint really sorry for in convinience
Jun 17, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Diagram of installing belt on amana washer
show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
Nov 02, 2008 | Amana ALW480DA Top Load Washer
How to change drive belt on Amana washer
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
Apr 23, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Washing Machines Logo
364 people viewed this question
Top Washing Machines Experts
