Question about Belkin (F5D7231UK4) Wireless Router
Followed the cd set up instructions to the letter every thing worked except it will not connect to the internet internet connection is ok when plugged straight into the computer
No internet
muscled
    Genius:
  • 1,269 Answers
Try to reset the router first. There's a reset button at the back of it. Press it for 20 seconds, then unplug the power to the router, unplug power to the modem as well. Make sure the modem is connected to the Internet/WAN port of the router, and your PC is connected to port 1 on the router as well. Now power on the modem first, wait for all the lights to go solid, when they are solid, plug the power back to the modem now and check if you can go online now.
Posted on Oct 28, 2008
Connection to internet
To make an Internet connection 1.Open Network Connections 2.Under Network Tasks, click Create a new connection, and then click Next. 3.Click Connect to the Internet, and then click Next. 4.Choose one of the following:
• If you already have an account with an Internet service provider (ISP), click Set up my connection manually and then click Next. • If you have a CD from an ISP, click Use the CD I got from an ISP and then click Next. • If you do not have an Internet account, click Choose from a list of Internet service providers (ISPs) and then click Next. 5.From your choice above, click one of the following:
• If you are connecting to your ISP using a standard 28.8 Kbps, 56 Kbps, or ISDN modem, click Connect using a dial-up modem, click Next, and follow the instructions in the wizard. • If your DSL or cable modem ISP connection requires a user name and password, click Connect using a broadband modem that requires a user name and password, click Next, and then follow the instructions in the wizard. • If your DSL or cable modem ISP connection is always on and does not require you to type a user name and password, click Connect using a broadband connection that is always on, click Next, and then click Finish. Use the CD I got from an ISP
• Click Next, and then click Finish. Insert the CD provided by your ISP and follow the instructions. Choose from a list of Internet service providers (ISPs)
•To create an Internet account using MSN Explorer, click Setup Internet access using MSN Explorer (U.S. only), and then click Finish. Follow the instructions in MSN Explorer. •To choose an ISP, click Select from a list of ISPs, click Next, and then click Refer me to more Internet service providers. In the Internet Connection Wizard, click Create a new Internet account, click Next, and then follow the instructions in the wizard.
Feb 14, 2017 | Internet Computers & Internet
CAN'T GET MY WIRELESS ROUTER TO WORK
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you are good to go.
Dec 26, 2011 | Zoom 4501 Router
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I try to connect to the internet it says the remote device won't except the connection
Please follow the following steps.
1. Open up your internet explorer and click on Tools tab 2. Click on Internet Options Tab 3. Click on Connections tab 4. Click in Lan Settings tab 5. Uncheck the box Automatically detect settings 6. Also uncheck the two boxes under Proxy 7. Click OK 8. Hopefully it will resolve your problem
Jun 09, 2010 | Computers & Internet
Quick instruction to install leeds asi/66887 wireless mouse
You need installation disc, if you have lost the CD, than go to this site Driver Update Software for XP Vista 7 8 and download their update tool. I hope I helped.
Micky
Feb 12, 2010 | Microsoft Wireless Notebook Optical Mouse...
Having followed all the instructions as per the 'set-up' disc I'm informed that there is no connection with the internet. the cables are ok , having been checked against other equipment. your unit does not...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
No Internet Connection with Zoom 4501 & HUAWEI K3520 3G Dongle
It is very easy.
Dec 14, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Your instruction for Messanger 9 did not work
Download the manufacturer's software ( by using the CD or from their website )
Once your webcam is working on your computer,you can configure it to Yahoo Messenger.
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, unless the software has a feature for this.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start.
DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
If you complete the above and still have problems - check to see if your cam is compatible with Yahoo
YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/uk/yahoo/messenger/messenger9/webcam/mstacamreq.html;_ylt=AghoQIvxhmhcugo.AOaNKaokPCV4 Any problems - click on my avatar and message me
Jul 20, 2009 | HP KQ246AA Deluxe Webcam
Internet connection
1st check your cable with the tester 2nd configure your router then the last configure your connection go to control panel then network connection then right click local area connectn then properties one click internet protocol tcp/ip then properties check obtain IP add automatically then obtain DNS then start to connect again
Mar 27, 2008 | Linksys BEFSR81 Broadband Router with 8...
Dsl internet connection sharing
Did you run the set up cd? If so, then try to do powercycle. Reboot everything. if your wired connection works then access the set up page by typing 192.168.1.1 on the address bar of the PC that is already online. Leave username blank, "admin"  (lowercase letters is your password). Click status, if you already have an ip address and Dns then you are good to go. If you dont have then do a mac clone under "set up" then check the password for wireless connection under wireless security. you can use that to log on to the wireless netowrk on your two pcs.
if all of these seems to be confusing, you can call. 18003267114 for manual help.
Oct 16, 2007 | Computers & Internet
Belkin (F5D7231UK4) Wireless Router Logo
186 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
