Question about Walgreens By Homedics Automatic Blood Pressure Monitor 1ea
Every time i chech my BP with digital monitor, after initial infaltion , the machine is stoping and restarting to inflate and then the reading is appraeing on the monitor. it is happing only in my case. what could be the reason? can anyone explain please?
4 Suggested Answers
  • 10 Answers
SOURCE: I use the Walgreens digital blood pressure
Wherever you attach it - there must be a pulsating artery; Some people have atypic artery locations, old embolism with collateralisation (arterys everywhere except the place you think they are). Try another arm/leg/finger. Try it on your husband/nice/neighbour. Look if the marterial has a defect - then the error occurs in anybody, or if it measures accurately in the postman and not in you _ then you must look for a,other place to measure. If you have cardiacabnsolute arrhythmia or a lot of backfires (extra systoles): forget electronic measuring devices. Buy an old one with a stethoscope
Posted on Jul 26, 2010
SOURCE: I keep getting low readings.
you should already be dead if your bp is 196/119.normal runs 120/80.hypertension starts at 140/90. wrist bp units are often incorrect. dump nurse and cuff. go see your doc or use the free units at kroger
Posted on Oct 07, 2010
SOURCE: I have a HD502 Walgreen
Hi, I'm sorry I don't have a solution for you. I have the same monitor but I'm actually looking for the "t" plastic part that unite the hoses together and connects into the actual monitor. Not sure if you got it to fix it but if you still have ir, are interested in selling that little piece to me? I would be greatly appreciate it. Thanks
Posted on Sep 27, 2011
What's causing air inflation problem?
then contact the company for a replacement
Jun 30, 2015 | Braun Bp-5900 Exactfit Plus Bp Monitor
How to calibrate omega 1445 bp monitor
My first question is how do you know it's not accurate? I would tee in a digital manometer (measure in mmHg), wrap the cuff around a glass bottle and let the cuff inflate. When it fully inflates the cuff...look at the readings between the monitor and your manometer. If they are within a few digits of one another, I would leave it alone.
Inaccuracies with patient nibp readings are usually related to improper cuff placement on the patient. There's usually a mark on the cuff to indicate where the cuff should be placed in relation to the brachial artery. I believe this unit utilizes oscillatory technology to determine readings and an improperly placed cuff can create inaccurate readings.
May 23, 2014 | Criticare omega 1445 BP Monitor
The cuff squeezes my arm too much and it hurts. The reading is way too high everytime. I don't know how to adjust it.
do not inflate the cuff too much. if you know your usual blood pressure, just add about 5-10 mmHg when you inflate it so that you won't hurt yourself. for example, if your BP is usually 130/90, squeeze the cuff to 135-140 only. but if you doubt that your BP is way much higher than that by assessing on what you are feeling, just do not squeeze the cuff further than 200.
Jan 21, 2011 | Life Fitness Ultra Blood Pressure Monitor...
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
The Sunbeam blood pressure kit doesn't inflate the cuff.
You have the same problem I do. The hose socket to the machine is broken.
Jul 10, 2010 | Sunbeam Digital Blood Pressure Monitor
Centrios wrist BP monitor, model 10A03. When pu...
centrios wrist monitor works to inflate and deflate monitor but displays "1" instead of blood pressure reading
May 21, 2010 | Health & Beauty
Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Mar 23, 2009 | Health & Beauty
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Walgreens By Homedics Automatic Blood Pressure Monitor 1ea Logo
111 people viewed this question
Top Walgreens Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Walgreens Health and Beauty Expert? Answer questions, earn points and help others
