Question about Dell Computers & Internet
I have a dvd that has four games on it but will not open
A dvd is stuck and cant come out
try these: Try turning the ps3 on and off and then hitting eject.
Do Not try to open up the playstation. You may do more damage than good.
Try to halfway insert another game, cd, or dvd into the playstation 3 and press eject.
Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game. At last, eject finally pushed hubby's NBA Live out of the playstation.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
Four red lights
Open it up and check the wires going to the dvd player. the four red lights are a dvd power failure. check to see if you could open the dvd tray.
Jul 05, 2009 | Microsoft Xbox 360 Console
Xbox 360 game reads as DVD
change your laser or replace drive
Feb 14, 2009 | Microsoft Xbox 360 Console
Reads the games but only says close tray and open tray
It sounds like you will need a drvie replacement or motor. Sometimes the magnetic disc on the motor comes loose and it sticks to the top of the dvd drive cover and causes it to not function. We can fix this for you if your interested email us.
xbox360fixer@verizon.net
Jan 11, 2009 | Microsoft Xbox 360 Console
Xbox360 that doesn't know it is one
I had the same problem,If it is under warranty send it in ,,, if not then you are going to open it up,, plenty of instruction on how to do this online (google it). see what type of dvd drive you have and then go on ebay and purchase an identical replacment drive. once you recieve it open up YOUR ORIGINAL DVD DRIVE and unplug the green motherboard looking thing on top(Big ONE) there should be four little tabs on this. put it to the side . now open up the new dvd drive and repeat but make sure you dont get these cards switched up.put the old key in the new dvd drive , plug in all 4 tabs,bottom one first. put back together and install back into xbox360. put xbox 360 back together put in disk and enjoy
Sep 29, 2008 | Microsoft Xbox 360 Console
My playstaition
the sony ps2 plays plays all games either ps3 games and othe console games .to play dvd games after inserting the disk first yu have to press three or four times the power puton contnously and the game automatically starts ok bye.
Jul 13, 2008 | Sony PlayStation 2 (PS2) Console
360 Won't read any disc
How long have you had your 360?
When you get open tray error it could be many things.
1. Dirty or scratched up cds ...... Take sum toothpaste and rub it on your scratched cds with your fingers in small circles. Wash them off with water , wipe them dry. This works dont ask how it does!
2. Your laser could be dirty ...... You could go out and buy a laser lens cleaner like the 1 for cd players. Or open it up use a q-tip and rubbing alcohol wipe the lens.
3. You can use the rubberband trick....... You'll have to open the 360 up for that fix. Plus im not sure it even works on the newer models. What it does it stops the laser from going too far off the disc when its reading it. This forces the laser to look for the commands on the disc to boot the game.
If you want to do the rubber band trick let me know.
Oct 16, 2007 | Microsoft Xbox 360 Console
D drive not working
I see this many, many times, invariably it is actually a Faulty CD/DVD. Unless the PC has been subject to some rough treatment the cables wouldn't "Fall Off" But it don't hurt to check.. The Dell Units usually have the Front Pull Off, and then there are screws to release the side panels.. OR they have Philips Screw Head fixings at the rear four corners, & in the middle. Or check your manual.
Sep 01, 2007 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
