Question about Maxent MX-42VM 42 in. Plasma HDTV
Maxent 42 inch problem
I have a 42 in Maxent Plasma Tv - when you turn it on there is a black verticle line and for example you are on component 1 -you see com on the right side of the screen and ponent 1 on the left side of the screen seperated by a black verticle line - there is also flickering white hoz lines that go from top to bottom of the screen - what would cause this - if you hook the tv up to a signal source you get a picure but it is almost like a double picture with the left and right picture is skewed -
  • 3 more comments
  • debelllll Dec 07, 2008
    2 Inches wide black vertical line in the centre of the screen of my plasma TV
  • ACSII Dec 20, 2008
    I have the Vertical Lines also, they come and GO!
    How do I keep them away!..
  • Anonymous Dec 21, 2008
    ihave same problem on 42 inch teckwood , what the f**k is it, how do i get rid
  • Anonymous Feb 07, 2009
    i have 42" Plasma, make TOSHIBA, there is one black line about 2", located 10" distance from right side of the screen, how can i solve this problem. pls help me to repair.
  • Anonymous Mar 13, 2009
    Blue screen with white, black verticle lines on the right side from top to bottom of the TV.  I just changed the Y-SUS & Buffer to get the video back, and now I have a picture, but the lines are on it now.  I can never just have something perfect.
  • 125 Answers
SOURCE: MAxent plasma will not turn on
open the back and reseat the LVDS cable(looks kinda like a computer data cable)...also check your other circuit board connectors..literally unplug the connectors..and reseat them...Question...is the set working now?...or is it not coming on?
Posted on Jan 31, 2008
  • 125 Answers
SOURCE: Maxent-42" HD Plasma
i havn't been able to get a tech manual yet for this unit..however...the plasma display has lost power...i would replace the X board and Y boards, including the Ysus boards(upper and lower Ysus boards.
Tech4lfe
  • 42 Answers
SOURCE: Parts for Maxent 42" Plasma TV
The TV was made by LG. You should be able to google an LG distributor or try ebay. The 953 is readily available but the 917 may be hard to find. Won't be cheap for new ones, around $350-$400 for both unless you can find used.
Posted on Mar 06, 2009
pilot210
  • 39 Answers
SOURCE: maxent plasma tv is showing only vertical lines.
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
Posted on May 19, 2009
  • 187 Answers
SOURCE: PERMANENT RED VERTICLE LINE DOWN THE SCREEN
Replace the timer control board
Posted on May 27, 2009
I have a 42 inch Maxent and it blinks like its going out??
Hello
Chec this power supply regulator baord to your tV for any defective components, or for loose solder points.2_20_2012_2_15_32_pm.jpg
Feb 20, 2012 | Maxent MX-42V1 42 in. Plasma Television
I have a single thin horizontial black line six inches from the bottom of the screen. how can it be fixed.
Hi.
The line is probably in correspondence of the low Y buffer board, located inside the TV and connected to plasma display. In that case the board must be replaced to fix the problem. One of the symptoms of a defective low buffer board is a black line that starts from the bottom of the TV.
Regards.
Ginko
Apr 25, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
Black line on Plasma Tv
Hi my name is Eric,
I hope I can help you with your issue ,
Bad news is you need a new panel. that is the screen itself.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Sep 27, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
Sep 04, 2009 | Maxent MX-42V1 42 in. Plasma Television
Panasonic Plasma screen suddenly has a verticle black line
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 03, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Nov 30, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Maxent MX-42VM 42 in. Plasma HDTV Logo
306 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
