Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Why does my RCR312WR remote flash repeatedly when I press the menu button on the remote?
After programming the code, I'll press the menu button and the remote only flashes and does nothing to the tv...
  • 12 Answers
SOURCE: Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
  • 346 Answers
SOURCE: My RCA450 universal remote control does not have a code search button
the rca systemlink 4 remote is very good.it has code search and menue
try also the menue button on the tv itself
Posted on Nov 16, 2008
SOURCE: I have a rca remote
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: I m trying to program my RC64 remote for Direct TV
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Posted on Jan 10, 2010
Testimonial: "Thank you thank you thank you!!!!!"
jyackle5
  • 8197 Answers
SOURCE: What is the code number
You can get the manual on the link below.
http://audiovox2.info/docs/common/RCR312W/RCR312W_OM.pdf
Codes on this link below.
http://audiovox2.info/docs/common/RCR312W/RCR312W_OTHER_CL.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 29, 2010
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
Need tv code for emerson tv model#EWF2006 using RCA remote model#RCR312WR
These are the setup codes for Emerson TV with this remote control.
10017, 10154, 10451, 10236, 10463, 10180, 10178, 10171, 11394, 11963
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
  5. If you want more details, check this.
Dec 26, 2012 | RCA RCR312W Remote Control
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
2010 mahindra scorpio: how do you program a 2nd alarm remote
You'll need to find the valet switch in your scorpio. It is in glove box, towards the top, near the metal clip in which the lid of Glove Box Locks. You have to turn "ON" the ignition. Press that button once.....Leave it Press that button again and hold it You'll hear a beep confirming remote programming mode Now press lock button of each remote to be programmed one by one for atleast 2 seconds You'll hear a small beep on each button press confirming successful remote registration Now leave that button and close all doors and check the remotes for programming
Mar 11, 2012 | 2011 Mahindra Scorpio
How do you connect the home link garage control to your car & garage?
Things You'll Need
  • Remote garage door opener
Suggest Edits
    • 1
      Turn your Chrysler vehicle off and press and hold the two outside buttons on your onboard opener system. Release the buttons once the red indicator light begins flashing. This will erase any previous codes programmed to your system.
    • 2
      Hold your garage door opener remote two inches away from the onboard system.
    • 3
      Press and hold the button you wish to program on your onboard system and the open button on your remote simultaneously. Release the buttons once the indicator light on the onboard system begins flashing.
    • 4
      Press the training button on your Chrysler's system until the light glows solid. If it does not glow solid, continue to the following steps.
    • 5
      Press the "learn" button on your garage door remote, located near the antenna wire on the back or side of the system, and return to your vehicle.
    • 6
      Press the training button on your on board system, hold it for two seconds and release. Repeat the press/hold/release step two more times and your remote will be programmed and ready for use.
Dec 10, 2011 | 2002 Chrysler Town & Country
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
I have a rcr312wr,I lost manual,I want conect it to dvd samsung...which is the code and the steps???
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Sep 15, 2010 | RCA 3-Device Universal Remote with...
I HAVE A RCA UNIVERSAL REMOTE MODEL RCR312WR WITH A ELEMENT BRAND TV. WHAT IS THE CODE I WOULD USE TO PROGRAM THE TV?
From everything I can find it doesn't appear that your remote has a code for Element. I did find the following that may apply to your remote. Give it a try.
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Aug 28, 2010 | Televison & Video
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 08, 2010 | Televison & Video
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
140 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
