Question about Cooling System for Ford E250
How do you change the coolant - Cooling System for Ford E250
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 207 Answers
Radiator or Transmission???
Posted on Oct 21, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How hard is it to change the cooling fluid in phillips projection tv.
The CRT coolant change is all mechanical which involves removing the crt and disassembling the coolant chamber so it can be cleaned then reassembled and filled with coolant the phillips CRT coolant kit from www.tvrepairworld.com has the coolant and the instructions for the repair on cd
Jul 31, 2011 | Philips 60PP9352 60" Rear Projection...
Where is the coolant sensor on a 93 century. 3.3 v6 I can't find where it is located. Top or bottom? Front or back?
A variety of sensors provide information to the ECM/PCM regarding engine operating characteristics. These sensors and their functions are described below. Be sure to take note that not every sensor described is used with every engine application. Coolant Temperature (ECT) The Engine Coolant Temperature Sensor (ECT) is a thermister (a resistor which changes value based on temperature) mounted on the engine coolant stream. As the temperature of the engine coolant changes, the resistance of the coolant sensor changes. Low coolant temperature produces a high resistance (100,000 ohms at 40°C/40°F), while high temperature causes low resistance (70 ohms at 130°C/266°F). The ECM/PCM supplies a 5 volt signal to the coolant sensor and measures the voltage that returns. By measuring the voltage change, the ECM/PCM determines the engine coolant temperature. The voltage will be high when the engine is cold and low when the engine is hot. This information is used to control fuel management, IAC, spark timing, EGR, canister purge and other engine operating conditions. A failure in the coolant sensor circuit should either set a Code 14 or 15. These codes indicate a failure in the coolant temperature sensor circuit.
It looks like the above, under hood, passenger side, upper engine area, mounted in front side of water outlet (according to Autozone.com).
Oct 08, 2010 | Buick Century Cars & Trucks
My thermostat pumped coolant into my intake manifold i changed my thermostat but i put tampoons into where my spark plugs go to **** up the remaining coolant and the strings came off. how do i get them...
without removing the head i don't see u getting them out
i don't understand how thermostat pumped coolant into intake manifold do u mean when you changed thermostat coolant splashed in throttle body if so that little amount of coolant wont matter now if some how cylinders got full of coolant just remove all spark plugs and crank motor over it will push all coolant out and what it didn't would end up in crankcase and oil change would take care of that
but un fortunately now only way to get tampoons out is to remove heads
Jun 11, 2010 | 1999 Chevrolet Malibu
Changed coolant and heater quit working
how did you change the coolant? did you remove a hose or just open up the valve at the bottom of the radiator
If you removed the lower radiator hose then you may have induced air into the cooling system
when the engine is cool, remove the coolant cap and start the engine
wait until you have a good flow of coolant out of the reservoir to ensure you have all the air out of the system
Mar 27, 2010 | 2005 Ford F-150
I get an intermittent "Coolant Sensor Bad" The FSM is clear, Bad mean the line to the coolant bottle switch is open.
The coolant sensor and the coolant level sensor are two different sensors. Your message center is showing (coolant sensor bad),not level sensor bad.
The level sensor only monitors the amount of coolant in the container
The coolant sensor senses the degrees of the coolant, which turns on the electric cooling fans. Change the coolant sensor, and the problem should go away.
Nov 16, 2009 | 1998 Jeep Grand Cherokee
Changed coolant sensor on 99 monte carlo, cleared computer, light
Which coolant sensor did you change? The one in the passenger side tank in the radiator.
Mar 19, 2009 | 1999 Chevrolet Monte Carlo
2001 Jeep Grand Cherokee 6 Losing Coolant
If your oil is white looking on the dip stick, you will have serious damage inside the engine.
Aug 04, 2008 | 2001 Jeep Grand Cherokee
Changing coolant instructions
go to this link they have some good pictures. just scroll down to about the middle of the page and you will see the picture links. Yes any coolant as long as its optical coolant for CRTs will work.
http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/Changing_CRT_Coolant_P15302
Mar 19, 2008 | Philips 43P8341 43" Rear Projection...
Cooling System for Ford E250 Logo
24 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
