Question about Saws
How to replace lockdown pin DW708 12" sliding compound mitre saw
I have a DW708 12" sliding compound mitre saw and I can't figure out how to remove and replace the broken lockdown pin.
  • 3 Answers
You do not have to drill anything out, if you are talking about the hold-down locking pin that keeps the blade assy locked down when not in use. I have created a tutorial for replacing the locking pin, you can find it here, http://mgfic.com/dewalt708_lockingpin.htm
Posted on Jan 26, 2013
  • 76 Answers
You are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
I casnt remove the centre nut from my c8fse chop saw
Hi, when I do this I insert a large screw driver into the blade saw to stop the blade turning, as you will need to turn the nut clockwise.
Aug 01, 2010 | Hitachi C8Fse Sliding Compound Mitre Saw...
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do I remove the threaded rod from beneath the turn table of a Mikita LS1013 Slide Compound Mitre Saw ? I have removed the two black turning/tightning handles but cannot see how the rod is removed.
if you removed the handle from the rod you would need to put a pair of pliers on it gently and remove it. or if you turn it upside down and remove the tube from sliding mechanism you can grip the rod from there and unscrew
Mar 25, 2010 | Makita 10" Dual Slide Compound Miter Saw...
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Dec 26, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
I lost my manual and need to adjust the bevel settings
Make sure its a compound mitre and not just a mitre saw. The check in the back for a round knob with degrees marks on it, theres your adjuster.
Sep 24, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
The vertical blade stop is not true vertical. What adjustments are there to adjust the stop?
If you look on the back of the saw where the pivot is, there should be a bolt on either side that should adjust how much bevel there is . As for a 90 degree angle, there should be a locking pin or stop to keep it from leaning out of square. Be sure that it is accepting the pin properly and that it is clean. Not sure if there is an adjustment on the sliding saw, but i know there wasn't on my dual compound mitre saw
Jul 26, 2009 | Makita 10" Dual Slide Compound Miter Saw...
Saws Logo
771 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
