Question about Radio Shack Pro-94 Scanner
Wired?? The scanner screen shows wired and will not clear even when I try to clear the scanner and also when I take the batteries out. Don't know what to do?
The reason the word "WIRED" is displayed on your screen is because there is something wrong with the PC/IF jack on the side. Use a little flashlight and try to see if something is jammed in that hole. If not then you can either send it in for service or you can service it yourself (you'll void the warranty if you dismantle your scanner). The jack is probably faulty and once it's removed your scanner should work fine. The pc/if jack is supposed to be used for connecting your pc to your scanner to transfer frequencies. This would save you lots of time if it were that simple. I've doinked around with it quite a bit and never really figured it out. I suppose you could call Radio Shack and ask for help but since they didn't include instructions in the manual for the pc/if feature, I'm betting that they don't know either. Bottom line- you can spend 6 hours trying to get the data transfer to work, or 2 hours typing in the frequencies. You don't need the pc/if port, so remove it, and badabing, you have a scanner that works. ps. you'll need basic soldering skills to do this. If you've never used a soldering iron then you better practice removing components from something thats already broken.
Posted on Jan 26, 2007
"Wired" suddenly appeared on my scanner. I followed the first suggestion and removed the D206 diode. My scanner works just as good as new now!!!!! Thanks!
Posted on Dec 06, 2009
Actually if this doesn't work the problem is a bad diode. next to the jack is a diode marked D206. this needs to be removed and you will be able to use scanner, just not use a computer to program it.
Posted on Apr 14, 2007
Wii says needs update in order to connect with Wii Store which would allow me to download NetFlix Ap. It is connected to the net but I keep getting error message that says update could not go through. It...
Hi there!
There are two ways to connect your Wii to the internet; you can connect to your wireless network (if you have a wireless modem set up in your house), or you can connect using a wired connection directly to your modem.
If using a wired connection, you will need to purchase a Wii LAN adapter and connect that from your WII into your wired router.
Once you have figured out what connection type you will use (and if using a wired connection, purchased and connected your Wii LAN adapter) you will need to take the following steps:
FOR WIRELESS CONNECTION:
  • Turn on your Wii and click on the "Wii" button on the bottom left of the screen
  • Click on "Wii Settings"
  • Click on the arrow on the right side of the screen and select "Internet"
  • Select "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click on "Wireless Connection" and then "Search for an Access Point"
  • Select "OK" and the Wii will display all the wireless networks it finds.
  • Select the wireless network that is yours.
  • If it asks you to enter a password or key, then your wireless connection is password protected and you will need to enter the password that was setup to allow access to your network.
  • Select "OK," "Save Settings," and then "Yes."
  • Your Wii will test the connection and you should get a message saying connection was successful.
FOR WIRED CONNECTIONS:
  • Connect your Wii to the Wii LAN adapter and connect that to your modem or broadband adapter. Please not that you will need to unplug your modem for a few minutes to reset the connection and you will also need to unplug the connection to your computer when you want to connect your Wii to the internet.
  • Turn on your Wii and select the Wii icon on the bottom left
  • Click the arrow on the right side of the screen and select "Internet"
  • Click "Connection Settings"
  • Click "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click "Wired Connection"
  • Click "Ok"
  • Your Wii will now do a connection test
  • You should see a message saying the test was successful
Hope this helps!
Jul 06, 2011 | Nintendo Wii Console
Siren is going off and I don't know how to stop it. It was installed about 9 years ago and installer went out of business. I think it is wired separately from the security panel. We are clear across...
Time to install another alarm system.Go to the power source just disconnect the battery power source,if the control panel don't acept the codes or respone to the codes anymore.If the alarm keep going off the police come out more than one,they'll give a ticket every other times they have to show up to check around.
Jun 05, 2011 | Ademco 1 Wave 2 Alarm Indoor Siren Vista...
Pro 84 locked up says on screen in program mode wired
Your scanner should only enter the WIRED mode if you have a clone cable plugged into it. The only way to clear the problem is to RESET the scanner. Unfortunately this procedure will also erase all the frequencies that are programmed into the scanner. RESET is covered on page 54 of the scanner manual -- if you don't have yours you can download and print a copy here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000516_PM_EN.pdf
Bill B.
Listening in since the 60's
May 27, 2011 | Radio Shack Pro-84 Handheld Scanner
THE WORD WIRED IS ON SCREAN
WIRED should only appear on the screen if you have a programming interface cable connected to the scanner. Assuming that you do not have the cable connected, you'll need to RESET the scanner to clear it and restore it to normal operation. This process will erase/delete everything that you've programmed into the scanner, so be prepared to reprogram it. To RESET the PRO-83:
- Power the scanner OFF
- Press and hold the 2, 9, and HOLD keys and power the scanner ON
- The word CLEAr will display to confirm the RESET
Need the manual for your scanner? You can download and print it, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Dec 17, 2010 | Radio Shack Pro-83 Scanner
My pro 94 scanner shows the code luired when turned on. How do I fix this?
I'm guessing that the display shows "wired" and not "luired." This mode, along with the code, is supposed to clear when the computer programming cable is disconnected. If you don't have a cable connected, your only option is to RESET the scanner to its original factory settings. Just a caution: resetting the scanner will erase/delete all programmed information -- you will have to reprogram all of the data that you've previously entered. To RESET the PRO-94:
1. Turn the scanner OFF.
2. While holding down the 2 and 9 keys, power the scanner ON. The message "CLEAR" will flash for about 5 seconds while the scanner resets.
NOTE: Do not turn the scanner OFF until "CLEAR" stops flashing.
Bill B.
Oct 27, 2010 | Radio Shack Pro-94 Scanner
It appears to be locked in "wired" mode.....how do I clr this code? I have never attempted to hook the unit up to our computer so I don't know how the code has appeared.
The best way to clear this glitch is to RESET the scanner to original factory settings, but beware -- this action with erase all data that you have programmed into the scanner. The scanner is useless if locked in the WIRED mode though, so I recommend the RESET.
- Press and hold the 2, 9 and HOLD keys while you power the scanner ON
- The word CLEAr will appear after about 3 seconds. Do not power the scanner OFF until this message is gone from the display.
If you don't already have it, you can download and print your scanner's operating manual here:
Bill B
Sep 27, 2010 | Radio Shack Pro-84 Handheld Scanner
Scanner says WIRED when i turn it on, and it won't do anything
A RESET may clear the problem, but it will also erase all frequencies and data that you've programmed into the scanner. To RESET the PRO-94,
- Turn the scanner OFF
- While holding the 2 and 9 keys down, turn the scanner ON. CLEAR will flash for about 5 seconds as the scanner clears its memory and restores factory settings. Do NOT turn the scanner OFF until CLEAR stops flashing.
Bill B
Jan 22, 2010 | Radio Shack Pro-94 Scanner
PGM WIRED
pgm wired how do i fix this?
Sep 19, 2009 | Radio Shack Pro-84 Handheld Scanner
MY pro-94 said on the screen lu,red or something like that !
Could the display be saying "wired"? This is what it shows when it is in cloning or programming mode. If it is showing this and there is no programming or cloning cable attached, check the programming jack to see if it is damaged.
Aug 10, 2009 | Radio Shack Pro-94 Scanner
Radio Shack Pro-94 Scanner Logo
245 people viewed this question
Top Radio Shack Radio Communications Experts
Steve
xxxxxx xxx
Mike Charette
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
