Question about Skil 3 in. x 18 in. Belt Sander - 7500
How to disassemble a skil model 7500 belt sander
I need to replace the brushes
4 Suggested Answers
wrightly
  • 140 Answers
SOURCE: I have a Skil Belt
http://cgi.ebay.com/4-x-21-3-4-sanding-belts-36-grit-qty-10-/310329120043?pt=Sanders_Sandblasters&hash=item48410e952b
this is the type of belt it uses (size rather) 4"x21 3/4" you can find them on ebay.
http://www.skiltools.com/en/ here is the official skil website. they can probably email you an owner's manual if you wish
hope this helps out. this one is vintage from what i understand
thanks,
mike w
Posted on Jul 07, 2011
  • 9 Answers
SOURCE: I just aquired a used
I recently acquired a Skil Model 409 Orbital Sander. Had to contact the company in order to get a manual. They emailed me the manual in about a week. I have published that manual here: http://409skil.yolasite.com
Posted on Aug 24, 2012
I order my belts from custom sandingbelts.com they are quick and can make whatever size, grit and backing you want. I have a skil 525 that is about 50 years old.
Posted on Nov 28, 2012
I have a skil sand cat 2.5 x 16" belt sander model 593 no manual how do I put on and take off sanding belt?
The people at Skil will provide the data you seek Contact them on-line via this link. https://www.skiltools.com/Parts-And-Service/Pages/Email-Us.aspx
Mar 04, 2015 | Skil Tools & Hardware - Others
Brushes not turning, 2 inch piec on one brush in place, the housing is spinning but not turning brushes
Hello there! It sounds like you may need to replace your brush block assembly. Try turning that drive shaft connected to the middle brush. All the brushes should be able to do a full turn simultaneously. If the brushes get stuck and cant make a full turn or if all of the brushes aren't spinning together then your brush block will need to be replaced. To purchase a replacement brush block simply follow the link below. Hope this was helpful!
Search Results
Sep 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do I install paper to Skil Dual Action Sander model # 7372?
Sander has 2 slotted rotating rollers one on each end the paper gets fed in as you rotate roller, which will grasp paper and hold, feed/wind roller with slotted screwdriver till paper secure. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Skil nbsp7372 TYPE 1 nbspDUAL ACTION SANDER 348542
Jul 28, 2014 | Skil Tools & Hardware - Others
My brush bar keeps falling down. We replaced motor but now the brushes don't spin.
Hi! If you've replaced the turbine & gear assembly and the brushes are still not spinning, a replacement brush-block assembly may be needed. The brushes counter rotate and need each other to spin. If a single brush is falling out, the brush assembly is broken. If the whole brush assembly keeps falling out, the drive pin shaft may be damaged. To order a replacement brush-block follow the link below.
Search Results
Hope this helps!
Jun 03, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Skil 593 belt sander manual required
Try the Skil website for product support. There may be a manual to download or have mailed.
Oct 21, 2013 | Skil Tools & Hardware - Others
Cannot tighten then belt on a skil 594 belt sander
Have you tried the next smaller sized belt? If you tried a 24", have you tried a 21"? ... or, if you tried a 21", have you tried an 18"? ... etc.
Aug 12, 2013 | Skil Tools & Hardware - Others
What causes my belt sander to leave black goo on the wood? I keep replacing the sand belt, I do not push the sander into the wood.
Maybe you are burning the wood. If the wood is hard (like oak or maple) and the grit is fine (like 100 or higher) then this can only be avoided by NEVER running it still in one place. Keep the sander moving quickly over the surface. In fact, you should start the sander BEFORE you touch it to the wood, and when you do touch the wood you should be landing it like a little airplane on the runway. As long as you keep the sander oriented with the grain you can move it forward and back as well as side to side. Just keep moving until you lift it off of the wood - this also helps keep the surface flatter. Good luck.
Jul 30, 2012 | Skil 3 in. x 18 in. Belt Sander - 7500
Air driven turbo brush
Is this the Lightning model? How old is it? You may have to just replace the belt.
Also, the front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Nov 27, 2011 | Fantom Vacums Vacuums
Skil 3 in. x 18 in. Belt Sander - 7500 Logo
140 people viewed this question
Top Skil Tools & Hardware - Others Experts
ray gallant
richie46
Are you a Skil Tool and Hardware - Other Expert? Answer questions, earn points and help others
