Question about Grilling
We have a jenn-air grill that is 12 years old. Should we buy a new one or replace the guts on the grill?
  • Grilling Master
  • 32,281 Answers
I doubt you can get replacement parts for this old grill.
I suggest you don't waste your time looking for parts and purchase a new one.
Posted on Feb 19, 2012
Testimonial: "Thks,"
SOURCE: Jenn-Air grill half burner issue
clean your venturi.
Posted on Jun 30, 2008
ButtFuzz
  • 463 Answers
SOURCE: outdoor grill igniter not firing
The actual ignition unit itself (not the battery) is dead.
Posted on Feb 27, 2009
SOURCE: Jenn Air lp grill won't light with the ignitor button
I just finished cleaning our starter on our jenn air. Over time, corrosion, rust and battery acid builds up on both the coils on the lid (positive side) as well as in the battery chamber and negative tip inside the chamber. I used sand paper and sanded the coils in the cap and the chamber. The coils need direct connection to the battery to create the charge. There are no instructions on this that I was able to find. I figured it out after about 3 hours of fussing with it. It worked immediately once I placed the battery back in. You may also need to clean the electrode tips near the burner. I used a q-tip. Hope this helps.
Posted on Apr 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Jenn-Air #720-0163 won't start
If there is no gas coming out of ANY burner - your REGULATOR has failed.
PLEASE CLICK HERE to see the replacement part and ordering info. (near bottom of page)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question!!
Posted on Apr 29, 2009
  • 14 Answers
SOURCE: My Jenn air BBQ grill will not heat up all of
Couple things could be happening here. If you do exchanges, have you used more than one different propane tank since you've had this issue? This eliminates the possibility of a low tank pressure and a faulty tank connection. Next you need to look over the burners and the propane flow tubing. Spiders LOVE the sweet smell of propane and make their webbing inside the piping that get's the propane up to the burners. At your flow valves/On/Off knobs you'll notice that the propane shoots from the valves into a pipe with an air gap to gain oxygen. Look in there to see if there's any webs. Also should be a gap were that piping meets the burners, so you need to look there too. Depending on the age of the grill, you need to look the burners over. Corrosion & rust can cause the flame/propane holes in the burners themselves to cake up and close up causing much less flaming/heating opportunity. Also depending how much you've used it, it could be grease/dripping/sauce caked up over them too so they may need to be detailed/cleaned. It's not a pretty job, but grill maintenance that should be done every spring. When the burners get caked is when it's really fun and you need to remove them and clean out the holes with toothpicks. Jenn Air makes quality products, but being a BBQ and outdoors, it's just as vulnerable as any other to elemental and use issues. One last thing to check, some regulators (the disk shaped part right where the hose attaches to the tank) have another air mixture intake there with a screen on one side. Make sure there's no water in it and the opening is face down if you have one like that. Otherwise it's restricting the flow of the propane. I haven't seen one of these in a while, but they're still out there so check it too.
Posted on Jun 10, 2009
Covert Jenn-Air 730-0171 grill from NG to LP (propane)
Yes you can buy a kit just google make and model then you should be able to find a kit.
Jan 23, 2016 | Jenn-Air Grilling
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I have a Jenn air microwave and it just quit the other day while I was warming water. It is about 7 yr old. Is it worth fixing?
I recommend replacing it, as you said it is 7 years old and prices have dropped on the new microwave ovens making it more attractive to buy. The repairs with parts and labor will approach the cost of a new one.
Jan 24, 2011 | Jenn-Air Microwave Ovens
Hi There, I have a Jenn Air Gas Grill that I purchased at Lowes with a lifetime warranty. My Model# is 721-0336. We need 3 new burners and two small spacers that go between the burners.
Hi, you have to contact Clagrill on 501-821-4050 to request for your parts. I think they have a free shipping policy within the US.....
Aug 29, 2010 | Jenn-Air Grilling
Jenn-Air Model 720-0061-LP. Burners will not
burner is blocked needs cleaning out remove burner and clean it or put it in clr , or buy new one
May 18, 2010 | Grilling
Cleaning surface grates on 10 year old Jenn-air Gas-electric
Spray them w/ oven cleaner, put them in a plastic trash bag, and let them sit overnight. They should clean up w/ minimal scrubbig.
Sep 18, 2009 | Jenn-Air Kitchen Ranges
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Grilling Logo
214 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
