SOURCE: manual
I have an extra copy of the manula for the PFAFF 783 Hobbylock. It cost me $12 plus $2 postage when I bought
it 4 years ago. Write me if interested. [email protected]
SOURCE: Pfaff Hobbylock 776
The best I can say is to change all your threads to different colors and get light colored material. Start with tenstion for all set to N - normal and experiment from there. Change one thread's tension at a time, sew a long strip and check out both sides and adjust as needed. Remember to start with new serger needles and a oiled machine. I'm not an expert - I just have had a serger for 15 years.
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel
counterclockwise to raise the needle bar to its highest position.
Loosen the needle clamp with the allen wrench and pull the needle out."
and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
SOURCE: Pfaff Hobbylock 788 Serger won't work
Does it still make noise? Maybe it needs a new belt or just some oil?
