Question about SanDisk Sansa Fuze MP3 Player
Will my sansa fuze charge even if the driver is not on my computer
It wont let me put the driver on my computer
  • SanDisk Master
  • 32,281 Answers
MP3 players charge up by the USB cable that is connected to a computer or by a 5 volt USB mains adapter.
Posted on Feb 19, 2012
SOURCE: sansa fuze,white screen
I have the same problem too.. This sucks.
Posted on Nov 02, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa fuze
Make sure the hold/lock is not enagged
Try another USB port
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
SmartAviator
  • 449 Answers
SOURCE: Sansa Fuze not being detected
Try using it with Power Switch to ON position. Ehtesham.
Posted on Jul 12, 2009
SOURCE: My Sansa Fuze Wont Turn On or Charge
Hold down the power button for 30 secconds to a minute, then let go and turn it on again as per normal. This is a built-in reset function.
It seems to happen for me when certain mp3's are played, i think they might be corrupt and the palyer doesnt like them, and so crashes.
Hope this helps!
-DaALC
Posted on Jul 19, 2009
meeknotweak
  • 341 Answers
SOURCE: my computer doesn't recognize my sansa fuze and i
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps.
Posted on Sep 29, 2009
Sansa fuze 4g isn't recognized by computer...won't charge, screen only shows "writing" screen when body of mp3 player is pressed together...any ideas?
When i plug my Fuze in the pc, it turns on, but doesnt charge, and isnt even recongnized by my pc. So i cant put anything on it and it doesnt even show up in device manager.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze is acting up
I m unable to charge my mp3 player. I have conneccted it to the computer on 4 diffrent times and it wont charge. what is the problem?
Nov 03, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze will not charge
Download the latest drivers for it first. Then turn on, then connect via usb, then go to my computer and you should see your device in the drive folder
Sep 02, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 2gb wont turn on or charge
Mine did the exact same thing, (Even the going to bed thing) I'm glad you posted your question. Incidentally enough after trying to turn-off and on for ten minutes, I pressed all the buttons a whole bunch to show it my frustration.....then it worked. (?) I don't know why, but I think that the computer going into hibernation or shutting off affected it.
Jun 23, 2009 | SanDisk Sansa Fuze MP3 Player
Hope this helps!
-DaALC
Jun 20, 2009 | SanDisk Sansa Fuze MP3 Player
The computer wont recognise my mp3
try messing with the usb settings on the mp3 player in settings/ system settings/ USB mode/ for a newer PC try MSC for an Older PC or mac try Mtp and if that dosen't work try auto detect just mess around with it fir a while
Apr 09, 2009 | SanDisk Sansa Fuze MP3 Player
Willl not detect
go into settings on the main menu, then go to system settings then go to usb mode and take it off of auto detect and put it on either MSC or MTP
Feb 15, 2009 | SanDisk Sansa Fuze MP3 Player
Wont work
Hold the Power switch to the off position for 13 seconds it will reset the system (it wont delete memory)
Feb 09, 2009 | SanDisk Sansa Fuze MP3 Player
My computer wont reconize my mp3 player
Down load the firmware on Sansa's website. I have a Sansa 250R and it wouldn't work with the new replacement usb (Griffin) cord I bought at Best Buy. So I bought a Sansa Fuze and the cord that came with it worked on the E250R. Huh? Yeah, go figure...and oh, that replacement Griffin usb cord I bought worked fine with the new Fuze. I came real close to buying a new battery for the E250R but instead invested that money in the Fuze.
Oct 12, 2008 | SanDisk Sansa e250 MP3 Player
Sansa Fuze not working anymore
My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
Jul 17, 2008 | Audio Players & Recorders
SanDisk Sansa Fuze MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
