Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Whirlpool Dishwasher GU15ooXTLT3
My dishwasher will not start or reset it is flashing on the normal cycle I have unplugged it and nothing seems to be working.
  • Whirlpool Master
  • 2,651 Answers
One of 2 things, either you have a bad door switch/latch assy and its not recognizing the door closing, or up have a "stuck keypad" preventing proper operation in which case youll need to replace the keypad/console. if you remove the lower acess panel there is a "tech sheet" explaining different faults and checks for your issue
Posted on Oct 26, 2008
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Read more:
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
How do i reset my whirlpool adg 7460 dishwasher ? programme seems stuck on end cycle?
Unplug it, move timer to start and plug back in. If it still seems stuck at the end it is almost certainly the timer. If it starts as normal, suspect the drain pump or pressure switch
Apr 22, 2012 | Dishwashers
Dishwasher won't reset, stays on gree-flashing light- Clean cycle
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
May 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting
Oct 24, 2009 | Dishwashers
Whirlpool Gold Quiet Partner Model # GU980SCGQ2 The dishwasher normal light flashes on and off continually. The dishwasher won't stop cycling now, everything seems to work normally other than it won't...
Dlc737, We apologize for your concerns with your Dishwasher. If you have tried to reset from the breaker and it has not fixed the problem then we would recommend scheduling service. We would be happy to assist you further. Can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to would be happy to assist you further.
Jun 09, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Problem with whirlpool dishwasher ADG957
Continuous flash with no pause is a Faulty NTC (temperature sensor)
Or according to whirlpool it might be that your keys are syticking.
May 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
electronics fail most often when new. would not be surprised to see you have a logic board failure.
a new unit should not have any issue that would contribute to a malfunction, so looking for door switch problems or motor problems seems like a waste. call the service center for the unit.
good luck
Apr 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
105 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
