Question about Aiwa Z-L700 Shelf System
Aiwa Z L700 - wont power -up
Power red light on just wont connect with remote control or manually - think its a timer/sleep problem?
4 Suggested Answers
mnelsonix
  • 58 Answers
SOURCE: Aiwa z-l700 won't switch on?
1. Verify you really have power at the outlet. If so...
2. You will need to open up the main boby of the device (amp portion).
3. On the circuit board where the power plug comes in, you need to look for a fuse or fuses. Do you know how to check these? This is most likely the problem. Good Luck!
Posted on Apr 07, 2009
SOURCE: Which Aiwa remote control unit to buy.
Went to manufacturer's website.
Posted on Dec 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: Have purchased a Hi-Fi system
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-Z-L700-manual/id/1076ci565/t/2/
Posted on Mar 23, 2011
Toshiba 61PJ7UA, turn itself off and will not start. Power on light is red but when you hit the remote to turn TV on it clicks but dosent turn on(no green light). I have the circuit boards (particularly...
HERE'S THE ANSWER TO YOUR PROBLEM:
I think the problem has nothing to do with your TV. I bet the culprit lies on the setting of your remote control. Maybe you set your remote into a sleep mode. When a TV has set into a sleep mode. It's power on light is still red but doesn't work. So all you've got to do is keep pressing the sleep button. After a few presses, it will definitely work. And, you can now enjoy your day watching TV. Thanks.
Jul 10, 2011 | Televison & Video
Can't reset lamp timer for new bulb
when you replace old lamp with new one the lamp timer not reset automatically the counter is a software data and you reset manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
RESET +LEFT ARROW KEY+ RIGHT ARROW KEY+ENTER (as show in picture)
Feb 10, 2011 | Sony VPL-ES2 Multimedia Projector
How do I set the snooze time?
Hello cazador1,
Lets get you setup with the automatic snooze function on the Aiwa FRA37 Clock Radio.
The manual for FRA37 can be found here.
On page 16 of 27 the information is as follows:
1. Set Alarm/Power to standby 2. Press the SLEEP button 3. The power will automatically come on and shut off after 59 minutes. 4. To set the time for sleep timer for a less amount of time Press SLOW repeatedly while holding SLEEP
To cancel the sleep timer press SLEEP OFF
I hope this helps you out!
A Pleasure,
Guide - Vexed Demon
P.S. If you feel this answer to your question was great. Please take the time out to review me and give me a great rating! I am trying to level up and become a premium member to help others like yourself! The only way I can do this is by your ratings! Thank you for your time in advance.
Jan 13, 2011 | Aiwa FRA37 Clock Radio
How do I connect the LV814PR Malibu remote photo control to the ML200RT Power Pack?
To connect the Malibu LV814PR photo control to the Malibu ML200RT:
On the bottom of the power pack you should have 3 terminals: A, B, and C. The trick to understanding how the photo control is connected to the power pack is to understand that the "C" terminal on the power pack is a "dummy" terminal. It is _not_ connected to the transformer in _any_way. It serves the same basic purpose as a wire nut, it's just a connection point.
To avoid confusion following these instructions, disconnect your existing wires from the lights to the power pack. (they should already be under terminals A and B.
To connect the photo control:
1...Connect the outside solid black wire from the photo control to the "A" terminal on the power pack.
2...Connect the center wire from the photo control to the "B" terminal on the power pack.
3...Connect the red striped wire on the photo control to the "C" terminal on the power pack.
4...Now reconnect the lights, except this time connect one wire from the lights to the "B" terminal (along with the center wire from the photo control) and the other wire from the lights to the "C" terminal (along with the red striped wire from the photo control).
Alternatively, one could not even use the "C" terminal and just connect those 2 wires with a wire nut. Kinda messy, hence, the reason for the "C" terminal.
If you want to have the lights on from dusk to dawn, remove both the red and black trippers and turn the manual switch to ON.
If you want the lights to come on at dusk and OFF at, say, Midnight, put the black tripper at Midnight.
Enjoy your lights.
May 20, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Does not power up.
chuck05,
You might try to find a reset button on the back of the unit. Also, the Aiwa website may have a "support" staff that can see if they have an archived manual or tell you which buttons to push. Also, check to see if the unit has a fuse in back. Finally, check a website called audio.manualsonline.com . It's a free deal where people exchange manuals and information.
chrisxx
Jun 03, 2009 | Aiwa Audio Players & Recorders
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Apr 07, 2009 | Aiwa Z-L700 Shelf System
I need the codes for a brightstar br100z remote for a symphonic t
Hold the set up button until the red light stays on on the remote. Press power until the TV responds. My sleep timer displayed after 23 presses (hotel room Magnavox TV). Stop pressing remote. The red light will then flash a few times once you stop. Problem fixed.
Feb 01, 2009 | Universal Remote Control Remote Control
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Aiwa Z-L700 Shelf System Logo
46 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
