Question about Yamaha HTR-5990 Receiver
Yamaha HTR-5990 when hooking up HDMI to DVI on Optoma EZpro 759 HELP
When i hook up the Yamaha HDMI to my DVI projector I get a HDMI error and my screen flashes and I also get a loud continuous beep from my speakers...my Projector is HDCP compatiable... I also have a HDMI Samsung HD 960 DVD player for the imput. I unpluged the dvd player still get a HDMI error.. so I unpluged the HDMI cable that was going to my projector Beep stopped and hooked up my cd player and it rocks.. but won't work correctly with projector.. can you help.. PLEASE.. Thanx in advance
HDTV GURU
  • 261 Answers
SOURCE: Yamaha - 5650/HTR-5640
Did you try going thru the setup portion of the owners manual? IF you need the manual you can get it online free. I realize sometimes people read the manuals and don't understand the technical jargon. Let me know if you need further assistance thur chat session and i can possibly step you thru it better in real time. Good luck Guru Jay
Posted on Feb 02, 2008
projdoc
  • 2237 Answers
SOURCE: lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
that's the way it's designed. the hdmi gives control to the projector.
Posted on Aug 19, 2009
  • 5 Answers
SOURCE: Audio keeps cutting out intermitenly on my
Is it going into protect mode???
If so, check your speaker connections. Make sure there are no loose copper wires hanging out, and that your splices are clean at both the receiver and the speaker.
Posted on Feb 13, 2010
dunnbiker
  • 8546 Answers
SOURCE: no compressed audio on hdmi
You probably need to take that issue up with the setup of the unnamed device originating the signal.
Posted on Mar 24, 2010
  • 21 Answers
SOURCE: what model of remote comes with this yamaha htr
The HTR-5990 comes with 2 remotes; RAV-356 for the main and RAV-21 for Zone 2.
Posted on Mar 26, 2010
Yamaha HTR-5990 Receiver the HDMI inputs only one works is the other switchable?
according to yamaha website you have 2 hdmi inputs, and one hdmi out on that unit
Mar 07, 2013 | Yamaha HTR-5990 Receiver
I NEED TO FIND A BULB FOR THE ezpro-610
This is it (in the USA) http://www.myprojectorlamps.com/projector/Optoma/EzPro%20610.html
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
Feb 16, 2011 | CTX Optoma EzPro 610 Multimedia Projector
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
No compressed audio on hdmi If I send compressed Dolby Digital to the HTR-5990 via HDMI, the indicator shows "PCM" and no audio is heard.
Mar 23, 2010 | Yamaha HTR-5990 Receiver
My projector optoma ep719 has a blue screen went turn on with or without cumputer hook up
please check the signal and the display properties as per SVGA or XGA resolution
Jul 16, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
Need new color wheel for EP 759
i would try to email optoma or parts guy localy that sell or fixes these see if he can order u it ok best way thx nick
Feb 12, 2008 | Optoma EzPro 739 Multimedia Projector
No sound from Yamaha HTR-5990
You must be sure that you also have "audio" cables connected to the receiver to make this all work. As far as the TV is concerned, the same applies....accordianman
Oct 31, 2007 | Yamaha HTR-5990 Receiver
CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
Yamaha HTR-5990 Receiver Logo
107 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
