Question about Kenmore 22942 Top Load Washer
My washer is making a load banging sound and the drum barely moves. We tried replacing the coupler but it changed nothing. What can we do or do we just need to just buy a new one?
3 Suggested Answers
SOURCE: Kenmore 417 front load washer
I have grease stains on my clothes, black rubber on washer was full of mold, I cleaned it best I can, was this the problem my clothes are getting ruined
Posted on Oct 24, 2008
SOURCE: Sears Kenmore front loading washer bangs and
I have a Kenmore 417, when it gets to the final rinse cycle the drum starts beating onto the left side of the washer and it leaks water
Posted on Dec 19, 2009
Washer making a humming sound want do anything else
what's the brand name and model number?could be the motor you hear humming,something could be stuck in the drain pump depending on the model you have or there could be a piece of clothing stuck between the tubs,a bad start capacitor but if the motor is humming either something is jammed and won't let it move or the motor could be bad but you have to send more info.
Dec 22, 2017 | Washing Machines
My washer doesnt twist black and force
sounds like you have a belt broken that moves the drum...replace and should be ok...
Nov 27, 2014 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Jul 09, 2017 | Maytag Atlantis MAV6260AWW Top Load Washer
When the washer spins the drum sounds like an airliner it also just started making a banging sound I can feel the banging on the right side of the washer
Try load it a little lighter and spread the clothes more evenly (in other words so that the weight is not all on one side.
Sep 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Front Loader Model #FWT449G5S00 banging on spin cycle. One bottem shock snapped replaced with new shock kit (twice) still bangs. At first I thought bang ( out of balance problem) was because of the broken...
The bearings on the drum may be going bad or the counter weight may be broken off or missing or heavy unbalanced loads. Reach inside and try lifting up on the interior drum. If it moves up and down or you feel any popping I would say the bearings are going bad. They usually make a lot more noise on the spin cycle also. Similar to an airplane taking off.
Hope this helps.
Aug 09, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire front load washer/rear control panel GSTR1670AS0 just started to make a VERY LOAD banging noise. I replaced the belt, but it is still noisy and then got the same banging result during the...
Could be Drum bearings, try Grabbing the inner drum and moving it front to back ,should have little or NO Play, assuming this is okay then check the counter weight, Concrete Slab on top of machine outer drum loose
Dec 06, 2017 | Frigidaire GSTR1670A Front Load Washer
My whirlpool top load New Model direct drive washer just recently started banging violently against the sides when spinning. The whole washer wobbles when spinning and it wasn't doing that before. I...
have you tried resetting the self leveling legs in the rear? you do so by tilting the machine forward, as you do you should a springy metallic sound, then let the machine back down and see if that helps. this should be done anytime the machine gets move to ensure a strong foot hold to the floor
Dec 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Sounds like something is knocking around in the back of the washer. On the spin cycle, the noise is very loud anyway, but it sounds like there is something banging around inside. The drum moves around...
ok open the door
make sure the thing is empty
try to move the inner tub
if you can shke it side to side anything but around
you have a broken spinner support
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore front load washer 417.41142000 drum banging while spinning
Hi...
Try to check this
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 08, 2009 | Frigidaire FTF530FS Front Load Washer
Kenmore washer elite top load
sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22942 Top Load Washer Logo
51 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
