Question about Beko Dishwashers
How do i replace drain pump in a beko dsfn1530 dishwasher
3 Suggested Answers
SOURCE: BEKO D 2731 FW Dishwasher Problem
yes man,it worked 1st time,cheers for that info.
Posted on Sep 28, 2008
HansPP
  • 2510 Answers
SOURCE: My Beko dishwasher DWD 5410
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Posted on Feb 19, 2011
Dishwasher is humming when turned on like pump noise but not starting the program
the first thing any dishwasher does is drain, so if its humming instead of the normal noise there will be a piece of glass or something similar stuck in the drain pump it will need to be removed and cleaned out
Oct 09, 2014 | Beko Dishwashers
Dishwasher not draining BEKO dw601
I had the same problem with a Beko. Turned out to be the impellor pump. Chap who came to me said it was cheaper to buy a new one. Sorry.
Sep 09, 2013 | Beko Dishwashers
Beko dishwasher not draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Nov 20, 2010 | Beko 24 in. D3421F Free-standing...
Have a beko washing machine and the water will not drain! Any ideas PLEASE
hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
Jan 29, 2009 | Beko 24 in. D3421F Free-standing...
Beko dishwasher 3731 not draining out all the water
Check if the drain hose is free first, if the drain lines are notblocked, then there is need to remove the drain pump and clean the hosein there, or replace the pump.
To check the pump there is need to remove a panel held with screws, there the pump must be removed and cleaned, a lot of water willcome out when removing the pump.
The job should be done by a technician.
You can find machine parts and diagrams by entering model number here.
Dec 18, 2008 | Dishwashers
How do i re-set my dishwasher
If by reset you mean cancel the programme, then you need to press and hold the start/pause button for about 10 seconds until the drain pump starts to run.
This will continue for about 2 minutes.When it stops, turn off the appliance. When you turn on again all should be well
Nov 30, 2008 | Beko 24 in. D3421F Free-standing...
Not draining water beko dishwasher
--probably food particles blocking impellor on pump--clear pump or drain hose is kinked or blocked where it enters pipe under sink .Always scrape plates clear of food particles before placing in dishwasher
Jun 25, 2008 | Dishwashers
Beko eco washing machine
Sounds like a pump problem. Could be a broken impeller, or something has got past the filter and has jammed it. Try removing the filter assembly inside, and see if anything is visible in the pump chamber. It may be too late and the pump is broken.
Oct 17, 2007 | Beko 24 in. D3421F Free-standing...
Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Jun 28, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
351 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
