Question about Zanussi Dryers
Dryer does not heat up
There is no heat in the dryer at all, it just blows cold air. I have read solutions like this for other models but I dont know where to find the heater box
My dryer work but it does not give heat ( kennmore 70 series)
model# 10062712101
ser: 1216293
i am trying to get the manual for my dryer from kennmore
Posted on Oct 26, 2008
Dryer stopped heating only blows cool air
you have to open the back off dryer,the r two thermostats. they are round held by 2 small screws. high heat- low heat. use volt meter to see which one is bad. if u put volt meter on wires,it will let you know which is bad. 30 to 35 a pc.
Mar 17, 2013 | Dryers
Dryer tumbles,blows cold air no heat,looking for access to fuses,dont know what part of dryer fuses are located
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 26, 2011 | Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Kenmore 90 series dryer works but won't get hot
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If the dryer is blowing cold air, and you stated that a replacement dryer works fine plugged into the same receptacle, you may have a problem with your power cord, or the internal heating circuits.
First, locate the terminal block at the back of the unit (this is where the power cord is installed) and plug the dryer back in. Verify that you have 220-240VAC across the two hot leads (RED and BLACK wires). If the voltage is not correct, you may just have a bad power cord. If the voltage reading is normal, you have an internal heating circuit problem.
Read through the link provided and let me know if you have any questions. If you require additional assistance, please let me know before you rate the solution. I hope this helps you.
Feb 27, 2009 | Kenmore Dryers
Dryer will not heat
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Jan 22, 2009 | Dryers
Kenmore model 76712 does not blow heat just cold air
Jan 22, 2009 | Kenmore 75962 Gas Dryer
Electric dryer only blows cold air......no heat
Your problem is associated with the heater element and or thermostats, you need to access these in order to determine the prob.
You have to lift the top cover and remove the front panel to do this.
Depending on your model of dryer, there are at least 2 ways to get into the dryer
It would take too long to fully explain the different ways to get into the dryer,so try this site which should give you all the info you need.
partselect.com
then click on free repair help then click on dryers, and then on my dryer will not heat up.
I would be grateful if you could let me know if you find the info you wanted from this site.
plz rate my solution.
Thanks.
Jan 03, 2009 | Whirlpool Dryers
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Blowing cold air
There is not a reset button on an electric dryer that I know of. If a dryer is blowing air at all, that tells me that the blower assembly and drum motor are working. If you have not heat it is generally caused one of the following:
1. Bad thermal cut-out - located near the heating element housing. Should read a SHORT (0 ohms on an ohm meter) if good. If bad, it is generally a good idea to replace the TCO along with the Hi-Limit Thermostat (mounted right next the TCO in most cases) because the TCO is designed to protect the thermostat and heating element. If the TCO fails, it is likely that the thermostat could also be damaged.
2. Hi-Limit Thermostat failure - located near the heating element housing. The thermostat opens when the internal heat reaches about 157 degrees (on most dryers). This helps regulate the dryer temperature and helps protect the heating element. If it reads a constant OPEN (infinity reading on an ohm meter), replace it along with the TCO (as mentioned above).
3. Bad Heating Element - located under the drum on some dryer models and in the rear on others. The element should read about 9-11 ohms if good. If they go bad, the element will generally burns itself OPEN.
I will need you model number (located near the dryer door opening) in order to give you better advice on how to access the inside of the dryer. Post back with comments and let me know. I hope you find this helpful.
PS I hope I didn't insult your intelligence, but some people are little more saavy than others, so I try to explain things in the simplest of terms.
Jan 14, 2008 | Dryers
Dryers Logo
123 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
