Question about eMachines E620-5885 Notebook
Computer has power but no video - eMachines E620-5885 Notebook
  • eMachines Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Feb 19, 2012
When I turn on my computer monitor it goes to sleep within a few seconds. What can I do?
For desktop computers: check that the computer is on. Make sure that the monitor is connected to the correct port on your computer. Some desktops have graphics ports on the motherboard and a separate video card. In that case, the motherboard port(s) will be disabled.
Try a different cable and make sure that both ends are secured properly. (If there are multiple input options on the computer and the monitor, try a different port. Sometimes, a port fails. There are adapters available for DVI to VGA or DVI to HDMI if you don't have extra inputs on the monitor.)
Try a new video card and check that your Power Supply is rated to power the entire system. (Some video cards will not work at all if the power supply does not provide enough power to the card. Some power supplies have multiple rails and can't give enough power even though the overall power is sufficient.) Unfortunately, if you have been using a video card, connecting the
If you are connecting the monitor to a laptop, make sure that the external video port is enabled. Some machines will have the port disabled to save power.
If this was the first time using the monitor, make sure that the computer was off when you connected the cable. Then turn on the monitor and select the appropriate input (if needed) before turning on the computer.
I hope this helps.
Jul 12, 2014 | Computers & Internet
I need to install a video card on a Sony VAIO VPC-EA36FM. I need instructions., video, etc.
Instructions
    • 1
      Make sure that you have the latest drivers from the manufacturer of your new video card.
    • 2
      Remove the video drivers for the current video card. Check the Start menu for any Remove utilities specifically for the current video card.
  • 3 Remove the current video card in the Device Manager. Now you're ready to install the new video card.
  • 4 Turn off the computer and disconnect it from the power source.
  • 5 Follow directions from the computer's user manual to open the case. In most cases, you'll just remove a side panel.
  • 6 Locate the AGP video slot. If there is a video card in it, remove the video card.
  • 7 Orient the new video card so that the metal bracket lines up with an open slot in the back of your computer and the gold contacts on the video card line up with the opening in the AGP connector.
  • 8 Push the new video card into the AGP slot with steady, gentle pressure.
  • 9 Connect any power cables to the power supply.
  • 10 Secure the video card in place with a screw through the card bracket into the computer case.
  • 11 Close up the case, following the computer manual's instructions.
  • 12 Reattach the power cord, monitor cable, keyboard and mouse.
  • 13 Power up your computer. Windows will detect the new video card and ask if you want to install it now. Click "OK" or "Yes."
  • 14 If prompted, direct Windows to the directory where the video drivers are located. Follow the prompts to install the drivers for the new video card.
  • BMW ACCESSORIES.
    May 31, 2012 | Sony VAIO Computers & Internet
    When i on my desktop it show blue screen and says no signal analog
    That means that the monitor is not getting a signal from the computer. There are several possible issues involved. 1) Make sure that the computer tower is on. 2) Check that the video cable is connected to the active port on the desktop. (Computers often have video connections on the motherboard and an added video card. The motherboard connection is disabled when the video card is active. Similarly if there are several ports (VGA, DVI, HDMI, Display port) only one may be active.) 3) Try a new video cable (if possible) and one of the other video ports (again if possible). 4) Try connecting a different monitor to the computer or connecting this monitor to another computer.
    Open up the computer and check if the card requires a separate power connection to the power supply. Make sure it is plugged in. Do the fans in the computer spin up?
    If a second monitor doesn't work or the monitor works on another computer, then the problem is with the video adapter on the computer, the power supply or the power switch. Please add a comment with more information about the type of desktop and the current video graphics adapter (on the motherboard or separate card). I will provide additional help if possible.
    (who has a computer in the company that needed a new monitor (power supply failed) a few months ago and lost the fan on the video card last week. Without the fan, the card overheated and shut down. Thus no signal to the monitor.)
    Oct 02, 2011 | Computers & Internet
    Check video cable on computer
    On the monitor unplug the power and video cable. Plug the power cable in, and then the monitor cable. Power off your computer, then turn on the monitor. After you power on the monitor, turn the computer on.
    Nov 08, 2010 | HP 2009M Monitor
    I cannot copy and upload my recorded video..how can i transfer the video to my computer?
    Hi, video can be transferred to your computer from the camera by using the USB cable that came with the camera. Just hook the cable up to the camera and the computer, and then you can transfer files to your computer by using the screen and joystick on the camera.
    The only requirement is that the camera has to be on AC power when you transfer files, so you'll have to remove the battery and set up the AC power cable and DC power cable before you can transfer any files. If you try it on battery power, the camera's screen will tell you to put it on AC power.
    Oct 02, 2010 | Panasonic SDR-H40 HDD Camcorder
    Best video card upgrade...that will actually work
    You should go to the HP support website and look up the specifications on your computer. They will tell you what kind of graphics support your system has (such as AGP 4X, AGP 8X, etc.). The next thing is to understand what kind of maximum power for the video card is supported by your computer. If you get too powerful a video card for your computer, the internal circuit breaker will be tripped and you won't have any video. If you don't intend on using your computer for intense video gaming, you should be able to easily find a sufficiently powerful video card that is an improvement over your current one while still working well in your computer.
    May 19, 2010 | HP Compaq Presario SR1330NX (PP161AA) PC...
    Got BSOD on my XP computer and have traced it, I think, to the video card - getting "no input signal - going to power save". Would this prevent to computer from loading or going into safe mode?
    Yes, a bad video card could prevent the computer from starting at all. Your monitor is going into power save mode because the computer isn't sending a video signal. This could be due to many things, power supply, memory, video card, processor. Try blowing all the dust from it and reseating all the components.
    Jun 02, 2009 | ASUS Computers & Internet
    No video on new Gigabyte GA-MA770-DS3 motherboard
    There are a couple things that you need to look at. The first is your power supply. I've had computers seeming to run fine with no video. Turned out to be bad power supplies.
    Does your video card require a power connection? Many high-end video cards need an external power connection. If the card has a power connection, use it.
    Have you gone in and checked the cmos settings? What does it say (if anything) for the default video?
    Now remove all connections to drives (hard drive and CD and try for video. Try it.
    Next, if possible, swap out memory.
    After you've tried everything (including maybe burning incense), time to try a new motherboard.
    May 27, 2009 | Gigabyte Computers & Internet
    No display (black) - power light is amber color
    The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
    Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
    Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
    Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
    Power to Computer
    No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
    Computer Power Supply Information Helping you with questions you may have about computer power supplies.
    Computer Post / Beep codes The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working .
    Installing a pc computer power supply Additional help and information about installing a computer power supply.
    Good Luck, Please dont for get to Vote/Thank You.
    Dec 22, 2007 | HP Compaq nc6320 Notebook
    eMachines E620-5885 Notebook Logo
    70 people viewed this question
    Top eMachines Computers & Internet Experts
    brian soufane
    Avishek Samaddar
    Avishek Samaddar
    Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
