Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Diagram on how to take apart the ice maker to fix lose parts
Hi: I have a Kitchen Aid refrig , with a indoor ice maker . The type that you push a glass up against the lever , and ice falls into glass . I am not the best at mechanical fix-its . What happened is the clear plastic piece and a part fell into the glass when getting ice. The part does not look broken , only fell from place its supposed to be . The flapper door , that seals the hole from where the ice comes from seems loose now . How do you get the front face off to fix it. Can you help ???? matcotoolsutah@aol.com
2 Suggested Answers
  • 409 Answers
SOURCE: Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Posted on Sep 17, 2008
Could some please post how to remover the ice maker from my kitchen aid model ktrc 19 m refrig thank you
Look right above the icemaker part that forms the cubes. Its usually brown in color, Just above it are 2 extensions of that brown part that has 2 screws going into the left side of the freezer, Remove the 2 screws and the unit comes out. The power plug for it is just to the back bottom of the ice maker. If you can see it you can probably just unplug it to stop the noise.
Apr 11, 2015 | Refrigerators
My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Jan 07, 2012 | KitchenAid KTRS22EM Top Freezer...
Icemaker is not working in my kitchen aid superba
Hi, If your ice maker has stopped working then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken.
All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | KitchenAid Refrigerators
Kitchen Aid refrig. Won't put water into the ice m
Hi Dan,the plastic hoses are removed by pushing up on the "ring"around the hose at the inet and pulling it out.
Nov 15, 2009 | Refrigerators
My Kitchen Aid freestanding ice maker keeps going into Clean mode. How do I prevent this?
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for: http://www.repairclinic.com/KitchenAid-Ice-Maker-Parts
RepairClinic.com
logonobyline3.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
hi there,
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen Aid Superba refrigerator
turn water valve off behind frig thie will of course turn off ice maker, but will solve water mes problem then work on source
Jan 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker doesn't work - no ice ejected
Krakus, there is no fuse in the dispenser assy., but there are two switches mounted on the control bracket. The posts on the brackets that hold the switches are really thin and it's possible that it broke. Therefore when you are pressing the lever you are not making the switch and sending the juice to the auger motor. Remove the dispenser cover by inserting a flat blade screw driver in the slots at the bottom. Pry out gently and the cover should pop off. Then slide it up and off. Now you will be looking at the control bracket and see the switches on the left and right side. See if the switch holder is broken. If this is the case your part number is 2183771. Not a hard job, just have to take your time. Im assuming that when you tested the auger motor you verified that the drive coupler was not broke. Catriver..post back
Dec 18, 2006 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
186 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
