Question about E-Machines T4511 PC Desktop
Unit will not power on, replaced power unit with 400 watt unit but push on button still will not power up.
What do I need to do to correct problem?
    Problem Solver:
  • 7 Answers
Start Simple...!
I know this may sound too simple, but if you are replacing the Power Unit due to and old one blowing, it may well have blown fuses. Check them! in all mains plugs related to PC.
Also, are ALL you connections made. I.e. take off the front cover and check that the power button connector is attached to both button and board.
what are you running?
do you have NVidia Cards Running in Dual sli mode? - this is power hungry, you'll need 500w plus, i have a 600watt unit for this (i run 2 x 9600's in sli mode - i know 400w would never cope with the power demands of CPU's -quad- and GPU's - Dual - plus the 3 or 4 fans you will have on-board.
A little more info on the machine you are building/running would help.
a common old circuit tester would help out here also, to find out if power -when switched on at the main rear switch - is reaching the board, Are there any leds etc on at all?
I hope this is some help, .... Double check all connections...
otherwise post back with system spec and i will find a more precise and definite answer for you..
Posted on Oct 26, 2008
Can I use a 412 guitar cabinet in a vehicle as part of the stereo system at what type of amp what I use to push that
You would want an amp at least the wattage of the speakers, I would go double the wattage, say 800 watts and fuse speaker so as not to blow them. This way you have power to spare if you upgrade.
press the helpful button
INSANE Car Sound Systems
Custom Car Stereo Sound Systems
24 000 WATT Car Sound System PART 1 of 2
How To Design Car Audio System
Jan 23, 2016 | AMP Music
I'm new to the Car Audio seen.I just bought four 6x9's.Now I need a good Amp to push all four of them.Here's what I have.Sony XS-R6945 4 Way 6x9" 800 watt Full Range Car Stereo Speakers Power...
Look for a 4-channel amp that pushes 50 watts RMS @ 4 ohm.
Make sure the amp is CEA-2006 compliant.
Ignore peak or max watts as these are arbitrary numbers.
More info here - sparky3489.webs.com
Jan 24, 2015 | Car Audio & Video
Voltage djm 400
You do not need to replace anything, buy or have a stepdown transformer
of at least 200 watts rating.
Step-down transformer specs:
220V input
110V output
However , there are other DJM400 versions that have a built in 220V
input. Have a tech to guide you.
Oct 22, 2012 | Pioneer DJm 400 Professional DJ Mixer
Turning on my computer by pressing the On/Off switch on front of desktop computer does not always turn machine one.
more likely the switch itself not retaining the on position
get to the switch and bridge the 2 wires to see it it stays on
Jul 21, 2017 | Dynex DX-400WPS 400-Watt Power Supply
Can 9690 -5AU Tower take 400 watt?
There are switch mode power supplies that have a rating over 400w.
I suggest you Google the Internet for these power supplies for suppliers and price comparisons.
May 29, 2012 | Computers & Internet
MALIBU 200 WATT POWER PACK. Just purchased this model. The photo on timed off has been working for a week now. But now, the lights just stay on and will not go off, no matter what setting is used. I...
You posted under Intermatic or Malibu power packs:
These units come with 5-year limited warranty.
Check that override button is working correctly and that trippers are in place.
If timer is defective, then exchange for new one.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 18, 2010 | Malibu ML200RT - Low Voltage Power Pack...
What power wattage is good for this MB P5N32-SLI SE Delux Motherboard Which power supply
depends on what else you have got plugged in, I would get a minimun of a 400 watt from a good manufacturer, so you will have a good supply of power over the main rails, most cheap 400 watt supply's cant sustain any where near 400 watts
have a google for power supply reviews
Jul 17, 2010 | ASUS P5N32-SLI Deluxe Motherboard
I have an AsusP5P 800 mother board and the unit won't power on.
I had a very similar issue like this, how many RAM modules do you have installed? if you have 2 DIMM installed try removing the memory on at at time(try interchanging the RAMS), see if turns on. if not might be the motherboard itself thats possibly defective.
Feb 14, 2010 | ASUS P5P800S Motherboard
New system build, shuts off after 10 seconds
If you have had this problem sence the system was built and your power supply is less then 400 Watts. You will need a 400 Watt power supply or higher. Check the specs for our motherboard.
Dec 05, 2007 | ASUS P5N-E SLI Motherboard
E-Machines T4511 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
