Question about Croton Chronomaster Stainless Steel Bracelet CC311166SSBK Watch for Men
Had a new battery installed in my CC311166 and now the Day will not change
I installed a new battery in my timex expedition watch and it worked for one day ,,, now dead again
The replacement battery could have ben defective or installed incorrectly.
Feb 07, 2017 | Timex Watches
Need help changing battery for my guess watch G85635L..tytyty
  • Remove back
  • Find battery. Identify type and note mounting arrangement for later installation
  • Obtain new battery
  • Remove old battery. Install new one correctly
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery for you.
Nov 28, 2016 | Guess Watches
How to change battery shark 88 freestyle
  • Remove back
  • Locate battery and identify type. Note battery mounting arrangement for later reference
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Install back
  • Set time, etc.
Sep 05, 2016 | Freestyle Shark 88 Watches
Battery change
  • Open back
  • Note battery polarity and remove
  • Install new battery
  • Close back
  • Set correct time
Jul 12, 2016 | Watches
I am changing the battery in my Disney wrist watch and it says to short-circuit the AC terminal and the battery surface with tweezers, AFTER installing the new battery. Where IS the AC terminal and how...
Welcome to FixYa!
You actually do not need to do that. Your watch should be up and running after you change the battery. Short-circuiting the watch is for restoring it to factory settings and it should be done by a watch professional. Doing a wrong short circuit will can damage your watch permanently.
Thank you for using FixYa. Have a great day.
Jas247
May 03, 2011 | Disney Lorus Rare Musical R2306AX Watch
Where do I find a user manual for a Timex Expedition (H2Y518)? I had Timex install a new battery and although the date 3-17 is correct, the day of the week is SUN. I have tried changing the date for over...
You are very observant! Timex watches don't have a way to adjust the day.
However, if you turn the hands clockwise you will see the day advance.
So, heres the secret, follow exactly:
1. Turn the hands until the day of the week shows the day before. If today is Wednesday then turn the hands until the watch shows Tuesday
2 Adjust the date to the day before. If today is the 17th then adjust it to the 16th
3. Now pull the crown all the out and and advance the hands until the date changes to the correct date, 17 in this example. This happens at midnight. Continue the movement in a clockwise direction for a few more hours and you should see the day change to the correct day.
4. Now continue to move in a clockwise direction until you have the current time. Remember that your date/day changed at midnight so if the current time is after lunch(noon) you must continue past noon to get to the correct time. If you don't do this correctly your date will change every day at noon instead of midnight.
If you don't succeed the first time, try, try again! Good luck, Michael, Watchmaker to the Stars!
Mar 17, 2011 | Timex Watches
My eco drive watch just stopped working... oddly enough it was a day after a day in the sun? It was fine and then I changed the time 1 hour foward and the next day nothing.
Perhaps it got too hot. The operating range for watches seems to be zero to sixty degree centigrade.
If left in a very sunny position it could have exceeded the higher temperature. If it doesn't recover by itself, then try a new battery.
It might be instructive to talk to the maker (address at Citizen.com) to confirm my suggestion before replacing the battery.
Mar 18, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Gucci watch looses 10 mins a day after battery change
Please refer this matter to expert. Kindly run through below website for assistance in finding the nearest outlet/dealers in your country.
Gucci
Apr 12, 2009 | Gucci 6700 YA067503
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
Apr 11, 2008 | Field and Stream F116GWBS Wrist Watch
Croton Chronomaster Stainless Steel Bracelet CC311166SSBK Watch for Men Logo
47 people viewed this question
Top Croton Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you a Croton Watch Expert? Answer questions, earn points and help others
